1996 F-350 question
I have my '96 for sale and have been asked a question that I'm not sure that i can answer. Mine has the 460 engine instead of the PS diesel.
A guy has asked me if the "gas engine can pull as much weight as the 7.3L diesel?" Thoughts on an answer for this guy? Thanks |
That big block should be about the same as the 7.3 worse miliage but about the same rating...though all i found was for a 95 with a gas motor around 12000 GVCW. i would bet that is about the same as the diesel. If the sticker on the door says that weight, that 460 will pull it, not to far from a gas pump but those were strong engines..
1 Attachment(s)
I have a 460 as well and I can't give the thing away. But I would answer yes,
Originally Posted by zzzzzz
(Post 2729080)
If your giving it away Ill take it anytime. |
130k miles new trans (auto) loaded, NO RUST OR ROT. would you think $4k is too much?
(Post 2729286)
The big block gas engines during those years always had a higher rating than the diesels did. The way they rated tow capacities was using CID and HP, 6.9/7.3 had torque not HP. The 6.9/7.3 still towed nice. It is not all about getting it moving either, you have to be able to stop.
(Post 2729286)
(Post 2729080)
| All times are GMT -5. The time now is 05:17 PM. |
