Polishing an aluminum trailer
No problem, that's what it's all about...My partner Donnie, has tweaked these Leverage formula's over the last year. What we have achieved is to make all of our Leverage products ECO FRIENDLY, as well as be the finest product to put on you're fiberglass, metal, glass, chrome, and aluminum, all at less of a price than our compeditor's. If you end up going to the Miami show, touch the boats with our product on them. You will feel exactly what I'm talking about. Leverage will be on over 19 go-fast manufacture's...Thank You Jeff Jassby
Thanks for the info.
Be carefull of the truck brighteners/cleaners, they have acid like hull cleaner, it will brighten the alum but will dull when put in the water,it also makes the alum etched/porous making it worse the keep bright,
The ibeam material seems to be a different grade of alum,easier easy to polish,My Myco I tried polishing it,it was to grainy/ruff it would take forever sanding and endless polishing,Also my tool boxes were mirror polished new, a few time in the rain water stained, I have polished it and put the metal protectant and it doen the same.
Latley Iv been taking a scoth brite pad top ,going with the grain,
Just so I understand it correctly, you use a Scotch pad (same one you would use in the kitchen)? do you just use it dry then apply the serum to the pad, then rub it in until it turns black, then hose off? I bought the serum that I plan on using on the trailer....I don't expect any miracles, but just want to make sure I am doing it correctly so that I am getting the most out of the time that I put in. Do you do the whole trailer then rinse (meaning you leave the black residiue on there for some time) or do you do a section at a time?
I do a section at a time..aluminum oxidation is extremely messy..The reason for doing it this way is so that you dont have to go through 30-50 towels, they gum up quickly. Heres how I did mine. grab a scotch pad, put some Leverage serum on there and rub away, use a little water to stretch product out as well as rinse the black oxidation off. You will have to do it a few times, then wipe with clean towels. Its quicker this way. If you want then follow directions on the bottle for the final results..if you have a buffer that helps as well..Good Luck..call me if you have any questions. Jeff
