-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Cummins 6.7? (https://www.offshoreonly.com/forums/trucks-trailers-transportation/207128-cummins-6-7-a.html)
tblrklakemo 04-17-2009 10:38 PM
Cummins 6.7?
Seems like the duramax and powerstrokes are the engines powering the trucks of choice here. Almost zero, zip, nada, talk of dodge. Anybody got a 6.7 cummins? Issues with the the truck or motor? Anybody running a DPF delete on it? We know the 5.9 is the standard by witch all others are judged.............
Comanche3Six 04-18-2009 05:58 AM
I have a 6.7 and two 5.9 dodge duallies. Zero problems. The Cummins engine is a commercial grade unit. If you get it with the cab chassis then you get the Aisin 6 speed trans. Also commercial grade.
tblrklakemo 04-18-2009 08:33 AM
Yeah, but you also get a detuned motor with the cab/chassis.
boatntrkr 04-18-2009 09:37 AM
I have talked to a couple people running the DPF delete and programmer. They like it alot..MPG gains and of course HP gains...alot of 6.7 folks use these guys.
www.hs-performance.com
NEVERSATISFIED 04-18-2009 04:47 PM
My buddy has a cab & chassis 6.7 which he has a DPF delete. He tows 3-4 days a week without any problems. Good combo!
J-Bonz 04-19-2009 01:07 AM
Curious, Does the DPF kit change the cal in the ecm to accept running with no Thermisoters?
*Dodge Makes Um, Cummins Shakes Um*
tblrklakemo 04-19-2009 08:12 AM
I think it just lets the engine accept the fact that there isnt any increase in backpressure from a full DPF and no need to force a regen.
baywatch 04-19-2009 08:20 AM
I've got an 08 Laramie 3500. Love the truck but it was in the shop 3 days last week for codes related to sooted up turbo and other issues related to the emissions crap. Truck is at 11,000 miles and I am a bit miffed about the issue.
I was planning to keep the truck stock through warranty period, but I can't afford down time and if I have any more issues the emissions garbage is going to start falling off.
I Drive at least 100 miles a day and run the exhaust brake all the time per the dealer recomendation. Never had any canister full issues just this Turbo BS last week.
I do like the truck and the exhaust brake in tow haul mode is awesome when towing. The 6 speed auto is 100 times better than the old 4 spd auto I had in my 05 cummins.
The true test will be next week when I am pulling the Apache around because that is by far the heaviest load that I pull. I did yank the factory crap reciever and put a titan 18k lb reciever on it. On paper the dodge has much friendier tow ratiings than the others as well.
Check out www.cumminsforum.com for more of the good, bad, and the ugly..
J-Bonz 04-19-2009 09:54 AM
That sounds about right, Plus they must alter the cal for the VGT & EGR since there is allot less BP
tblrklakemo 04-19-2009 10:51 AM
yup....i would drive it home off the lot, and then disable the EGR and DPF, stright pipe it, and cap the EGR unit. Bottom line is the DPF and EGR are not good for the motor.
Catmando 04-19-2009 03:09 PM
You better HOPE you don't take it to the dealer again, because if you CHANGE anything they will void your warranty.
tblrklakemo 04-19-2009 04:39 PM
We could spend all day debating the magnuson-moss warranty act, but that would be little more than an exercise. As long as you arent going in for any engine warranty work you are fine. B/c nothing under the hood has anything to do with anything else on the truck. Besides, the bulk of the warranty claims are caused by faulty DPF units boogering up the computer. Get rid of the DPF and EGR and, in theory, you arent at the dealer for any engine issues.
boatntrkr 04-19-2009 08:13 PM
Key words here..."in theory". But if any one of the other sensors or hundreds of parts goes out on the engine or transmission under warranty and the DPF is gone and you have put an aftermarket program in place of the original ECM program theres a 99.9999% chance, they'll deny you.
On the other hand, alot of problems are the DPF codes, low fuel milage etc etc...so if your looking for reliability and fuel milage with extra pulling power over "maybe i'll need the warranty" id delete it.
In an ideal world, if something did go wrong, you could unbolt the aftermarket DPF delete exhaust and install factory stuff. Then reload the ECM with the factory settings...and hopefully leaving no codes from the programer for the dealer to find.
Another good forum on diesels is www.thedieselgarage.com
