What Do I Do With This 2008 F450? >
Old 06-26-2009 | 10:04 PM
  #91
Originally Posted by mcraymond3
Just curious. A question for the GM and Dodge guys. Are you concerned about GM and Chrysler filing for bankruptcy? If no, why not? We are seeing a lot of loyal GM and Dodge guys coming over b/c they are glad that Ford did not take any bailout money. What are your thoughts?
Wait, Ford just got a $5.9 BILLION Gov't loan!!! Although the term BAILOUT wasn't used, a loan is still a loan, meaning terms and a payback schedule.
I only wish Toyota would have went ahead with their 3/4 and 1 ton trucks.
RaceRPM is offline
Old 06-26-2009 | 10:13 PM
  #92
$5.9B wow first I've heard of that. Ford should use that money to fix its 6.0 and 6.4 problems.
That Hino diesel was way underpowered for it size. Maybe Toyota felt like it wouldn't be able to compete with the Cummins and Chevy diesels.
(BTW my sister lives in Raleigh.)
Catmando is offline
Old 06-26-2009 | 11:35 PM
  #93
jfm
Originally Posted by rssteiny
I here you man i love my 7.3 these things will run 400k no problem other than a cam senser or 2.
Felt the same way until tonight. Driving home after a smoke and drink with the bro-in-law and something on the top of the motor sprung an oil leak like old faithful. Pressure dropped and I shut it down, I hope in time. Top end is a pool of oil and the trans and under carriage is covered from run off. I hope that it isn't major and that no damage happened. Want to sell yours?
jfm is offline
Old 06-27-2009 | 05:21 AM
  #94
Sounds like the turbo gave up. I'm not sure...could be an oil line to the turbo?? Those in the know?
pachanga is offline
Old 06-27-2009 | 06:21 AM
  #95
Dock Holiday's Avatar
Charter Member #34
High Pressure Oil Pump
Mine started to leak around 60K and it was a simple easy fix. It makes a big mess but it is not a real big deal. I think the repair was under $200.00 if I remember correctly.
Dock Holiday is offline
Old 06-27-2009 | 08:41 AM
  #96
LIKE MY DAD ALWAYS TOLD ME ,,,,,.
F. ix O. r R. epair D. aily .
And F. ound O. n R. oad D. ead
DareDevil is offline
Old 06-27-2009 | 09:13 AM
  #97
sounds like the HPOP line to me too.
boatntrkr is offline
Old 06-27-2009 | 09:43 AM
  #98
Powerstroke turbos are good for only about 200,000 miles, so if he's right around that mileage it's most likely the turbo.
Catmando is offline
Old 06-27-2009 | 09:52 AM
  #99
To be fair, Cummins motors sometimes have problems early. Exhaust leaks, turbo problems, lift pumps etc. Rare but it does happen. Mine has had ZERO problems in 62000 miles.
Catmando is offline
Old 06-27-2009 | 01:28 PM
  #100
jfm
I don't want to high jack the thread but thanks for the pointers of what to look for. It was the high pressure pump but just a block off bolt came loose. New o-ring and a little muscle and back on the road. Thanks again
jfm is offline
