-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Anyone tow with a 6.0 Suburban 2500? (https://www.offshoreonly.com/forums/trucks-trailers-transportation/212731-anyone-tow-6-0-suburban-2500-a.html)
BowenCT 07-10-2009 09:19 PM
And if so, how is it?
BowenCT 07-10-2009 09:20 PM
Huh, no avatar??? Looks like my membership expired..........
t500hps 07-10-2009 09:40 PM
I have an 03 with the 3.73 gears. Towed our 8,000lbs (plus fuel/trailer) 31 ft Formula fine but that was the max. When I bought our 382 I quickly needed a bigger truck.
BowenCT 07-11-2009 08:59 AM
Thanks. That's about where I'm at; my 303 is about 7300 dry. I figured it'd be maxing it out.
bjablonski 07-12-2009 08:45 PM
I have an 08 2500 suburban and pull a 35 fountain. It does a nice job but getting it moving from a stop will need a lot of right foot.
I just got back from the Oshkosh Poker run and averaged 9 mpg with the air on the entire way.
Sydwayz 07-12-2009 10:06 PM
If you are bent on an SUV, get the 2500 Suburban with the 8.1L gas engine. I've towed 12K+ with a 2500 Avalanche with the 8.1L. 12K definitely taxed the 2500 AV, but ~8500 lbs. is not a big deal at all.
BeakBoater35 07-14-2009 05:35 AM
I have the same combo...35 fountain and 2008 Suburban 2500 with 3.73 gears, 6 speed transmission. Tows fine.
My understanding is the 6 speed is noticably better than the older 5 speed.
c_deezy 07-14-2009 05:56 AM
The new 6.0 motor (07+) is a lot better too.
