-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   disc brakes [ need help ] (https://www.offshoreonly.com/forums/trucks-trailers-transportation/215595-disc-brakes-%5B-need-help-%5D.html)
tim brown 08-24-2009 08:42 PM
if I remove the drum brakes on my trailer and replace them with disc do I have to remove the residual valve ? if so how do I remove the master cylinder ?
45SS 08-25-2009 11:03 AM
On my trailer I was able to order and replace the whole tounge assembly with the correct master cylinder already in place. All I had to do was remove three bolts and the brake hose. Reassemble and bleed.
Beak Boater 08-25-2009 11:26 AM
Depends on your coupler, but probably, here is a link that has alot of tech help. should answer alot of questions. http://www.championtrailers.com/techsup.html
