-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   f250 lowering kit???? (https://www.offshoreonly.com/forums/trucks-trailers-transportation/216383-f250-lowering-kit.html)
fastlane40 09-07-2009 03:06 PM
I've got a 06 f250 crew cab(4 big doors)7.3 4wd i want to lower.It has leaf springs front and rear.Does anybody know if there's a kit available?Thanks
Sydwayz 09-07-2009 05:45 PM
A 2006 with the 7.3L? They stopped putting the 7.3L PSD in the Superduty in 2003. I'm not sure if its different in Australia vs. North America.
fastlane40 09-08-2009 07:43 AM
1 Attachment(s)
Must be.I've got a 2006 with the steering wheel on the right hand side.
gofastkyle 09-08-2009 09:53 AM
in 05 ford went to a coil spring front end in the us. if you can get a part # off the leaf spring we could tell if the 04 and down design would work,or if its something completely different.
fastlane40 09-08-2009 02:45 PM
Okay i'll see what i can find.The f series was stopped here in 2006.Still popular and you won't believe the prices.
Search "carpoint" in Australia to check them out.
LapseofReason 09-08-2009 04:47 PM
Put 05 USA spec. Excursion springs in the front and the block in the rear. Be about 2 inches lower.
LapseofReason 09-08-2009 04:49 PM
Did you ever get the 6.0 POS motor over there ?
gofastkyle 09-08-2009 06:52 PM
ford used 2 different blocks, a 2 ", and a 3 1/2". you probably have the 2". remove the factory block and rest the springs right on the axle. new u-bolts will need to be used. if your going to tow airbags would be a good idea. the excursion front springs should lower the truck. new shocks all the way around wouldnt hurt either.
Sweet Nmocean 09-13-2009 07:13 PM
I would love to lower my 04 f250 4x4, it is to tall for my garage. I think 2 inches would let it in.
fastlane40 09-14-2009 04:57 AM
No we never got the 6 liter here.They last came into the country in 06 with the 7.3.They are so popular though.
Get on Carpoint in Australia and search f250.You will be shocked at the prices.
Hard to get Excursion springs over here.They were never released.
