New Ford 6.7
1 Attachment(s)
I sure hope Ford has done all their homework and get this one right. Three times and you are OUT and I don't think they can afford another 6.0 or 6.4 mess. There are a lot of us out here with GOOD 7.3's that would like to update to the newer body style so I hope that will be back in top dog position next year. The heads are mounted upside down and the Turbo is where the intake used to be. That is thinking out of the box.
The following copied off website: After releasing some exciting technical info on an all-new Power Stroke engine for the 2011 F-Series Super Duty, Ford has now announced plans to officially unveil the new diesel pickup at the Texas State Fair, with sales starting in the Spring of next year. Under the hood of the new F-Series Super Duty will be a revolutionary new 6.7-liter Power Stroke turbo-diesel engine. The all-new engine promises a, "significant improvement in torque, horsepower and fuel economy," says Ford in a press release, stating that this new F-Series Super Duty would continue to be a class leader in both payload and towing. It will also be significantly quieter than past diesels. Numerous high-tech innovations have been employed in building this new engine, starting with a compacted graphite iron (CGI) engine block that Ford says is twice as strong as standard iron blocks. This was deemed necessary due to the increases in power output. The new engine makes use of a Honeywell single variable turbine turbo (similar to the one found on the Porsche 911 Turbo), but takes turbo technology a step further still. Instead of one, there are two compressor wheels driven off a single turbine impeller, working like a bi-turbo setup that gives the engine a fast response time with little lag as well as the power of a larger turbo. Visually, the new engine looks remarkably different, due to the fact that the intake and exhaust systems are the reverse of a conventional engine. The exhaust manifolds sit in the valley of the big V8 engine, while the intake manifold is on the outside. This means the cylinder heads are essentially flipped around. By significantly reducing the amount of exhaust piping, lag is reduced considerably. Additionally, this new packaging moves the hotter elements of the engine (like the turbocharger and exhaust pipes) away from the intake areas, ensuring a constant supply of cool air to the engine. And as for that turbo, it sits in the valley between the cylinder banks. Due to its location, spool up is considerably faster and the engine's overall balance is improved. Another major benefit of this setup is that that cab no longer has to be removed from the frame if work needs to be done on the turbo. The fuel-pump, EGR (exhaust gas recirculation) components and the thermostats are also easily accessible from the front of the vehicle. Ford still hasn't released any info on how much power the new Super Duty makes, but we'll be sure to report on it as soon as they do. |
My latest diesel power magazine said it will be in the 350 hp and 700 lbft tq range.
1 Attachment(s)
Originally Posted by Dock Holiday
(Post 2950677)
I hope they unstack the headlights too. :eek: |
These trucks will me out may of 2009...
Originally Posted by DOUBLE OR NOTHIN
(Post 2950871)
I read 380 hp and 705 Tq for the Powerstroke 6.7 then the 6.9 duramax was to be 390/690. I also read that Ford is still tweaking and wants to come in at 400hp... but who the hell knows..1/2 the stuff we read is all hype... just like Obama:lolhit:
Originally Posted by Jassman
(Post 2950996)
Sweet, get ready for a killer cummins too. |
Originally Posted by tblrklakemo
(Post 2952989)
(Post 2953102)
is it coming out the same time..where can I read about it. Thanks Jeff
oh, havent read anything yet......just noting that the big three diesel trucks have been playing this game for some time. if history does indeed repeat itself, we are in for an even more beefy cummins in the future. it does appear that the 2010 cummins will carry over from 08-09. |
Guys give me a run down on the 7.3.It's all we got over here.Torque?faults?.
Originally Posted by fastlane40
(Post 2953154)
Displacement: 444 cubic inches, 7.3 liters Configuration: V-8 Compression Ratio: 17.5:1 Bore: 4.11 inches Stroke: 4.18 inches Injection: Direct injection, HEUI (hydraulic electronic unit injection) Aspiration: Single turbocharger Valvetrain: OHV, 2 valves per cylinder Oil Capacity: 12 quarts Weight: approx. 920 lbs dry Horsepower (peak)*: 275 HP @ 2,800 RPM Torque (peak)*: 525 lb-ft @ 1,600 RPM *peak refers to the highest rating given to the engine during its production. 7.3 L Power Stroke Facts The 7.3 Liter Power Stroke is similar to the International T444E. The T444E is essentially the same engine as the 7.3 Power Stroke, but the "Power Stroke" name is only designated when the engine is used in Ford trucks. Power output and maximum RPM are the only significant differences between the engines. T444E stands for: Turbocharged 444 cubic inch Electronic (as in electronically controlled). The T444E has been made available in applications above 60,000 lb. GVWR, and extremely popular in the medium duty truck market while it was available. The 7.3 Liter Power Stroke was ranked in Diesel Power Magazine's top 10 diesel engines ever produced. Over 2 million 7.3 liter Power Strokes are still in operation today. Over 2 million 7.3 liter Power Stroke equipped Ford trucks are in operation. That's more than Chevrolet, GMC, and Dodge diesel equipped trucks combined. Though considered outdated when compared to today's diesel technology, the 7.3 was considered to be the leader in diesel technology during the time it was produced. |
Ford should have kept it considering the 6.0 gave many people problems, but keeping the 7.3 up to date with our BS emissions proved troublesome and expensive.
Diesel engines along with the carbureted 2 stroke engines are the most polluting motors on the planet. They had to be cleaned up. Common rail fuel injection and DPF/EGR sytems were the quickest way to do that. Compared to the Isuzu(Duramax) and Cummins engines, the 7.3 was deemed to expensive to update. The big rig motors got the same treatment. And let's not even talk about container ships and the bunker oil they burn as fuel. :rolleyes: Nasty. |
| All times are GMT -5. The time now is 07:17 PM. |
