-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Key stuck in Jeep ignition (https://www.offshoreonly.com/forums/trucks-trailers-transportation/217179-key-stuck-jeep-ignition.html)
BL6 09-20-2009 03:47 PM
My son drives a 2000 Cherokee. He accidently took the key for mama's 2006 Jeep and tried in his. Now it will not come out.
There is a plastic cover on steering column he took off. Appears to be a button on bottom of cylinder but does nothing.
Ideas? thnks!
BL6 09-20-2009 04:49 PM
Vise grips, hard yank, Bingo!
wannabe 09-21-2009 03:41 PM
Bigger hammer theory always works!
Wannabe
robwkamm 09-22-2009 07:41 AM
is the lock /ign switch a square style? the tumbler has to turn to pull the cylinder out of it. i think you have no choice but pull yank it out.
Beak Boater 09-22-2009 08:35 AM
My wife has a 2000 Jeep also. The right key for the car has been stuck in it. Try moving the steering wheel a little to take pressure off the column lock and pull key at the same time.
paston1 09-23-2009 03:13 PM
The tumblers wear out over time. Have had several cars come through the shop with this issue. Sometimes the pull and yank method works other times you get to put a new tumbler in.
