Discs without a doubt.
And Electric over Hydraulic actuator. Best $700 you can spend. |
Originally Posted by Blueabyss
(Post 2961032)
I can tell you from experience that you need brakes on both axles . Just bought a new trailer .. This one has 4 disc surge brakes and stops GREAT. My last trailer had discs on 1 axle and they burned up quick so I removed them. I could not tell any difference when I had discs on one axle compared to no brakes at all. Boat is a 24 ft vip vindicator around 5000lbs wet and loaded.
Chris Now I just put all new 12" Kodiak disc brakes on front axle only and it works too good; my mileage is down... I would not think you need 2 axles with brakes until you go over 32 feet; with the proper tow vehicle, of course. |
Tow
I tow with a 2004 2500 dodge quad cab 4x4 . Yes it did seem safe with out brakes on the trailer. What I ment was I could not feel any stopping power what so ever from brakes only on 1 axle. Now that I have a trailer with brakes on both it hardly seems like i am towing anything as far as braking goes. I do agree the Hyd over elec is the way to go..
Chris |
Disc, brakes on only one axle can cause what is called spring or suspension wrap up. A trailer with only front axle brakes forces the frame to accept full stopping torque in a concentrated area, the trunnion. In the event brakes are applied when a bump or pothole is incurred the frame may bend due to shock load. Otherwise, the suspension on the brake axle simply twists or torques, thus,wrap up.
We use electric/hydraulic disc on larger trailers. However, a good surge coupler w/ disc on both axles also works well, for your application. |
The thing to remember about surge brakes is they need that initial jolt from the tow vehicle to push the master cylinder and start the braking action. I've got a load that is at my trucks maximum limit with surge brakes, and for the most part we have never had a problem. One day it was raining and when I went to stop, the truck started sliding, the ABS TRIED to stop the truck but I couldn't get that initial jolt to get the trailer brakes to actuate and ended up getting pushed through a intersection by about 30 feet. We got extremely lucky in that there were no cars in front of us and my light turned from red to green before I slid through the intersection. Things could have gone a lot worse...
EOH is the very next thing that will be done to that trailer and a MaxBrake will be going in my truck...unless we find a Top Kick soon :D |
Originally Posted by c_deezy
(Post 2963334)
In a perfect world the EOH is the ultimate. However, the controller may need a little adjustment, the connections may have a little corrosion, we may use a different tow vehicle....
A GOOD 2 5/16" coupler rated at 10,000+/- that is well lubed is pretty user friendly. The downside to an actuator, some have not been used enough to break in before corrosion sets in to close tolerances and encourage sticking. Further, the trailer manufacturer may have painted on a tolerance critical area or failed to lube or failed to final test the force to actuate. |
| All times are GMT -5. The time now is 05:40 AM. |
