Anybody Have Any Pics Of Trailer Washdown Water Holding Tank ?
I had wash down tanks on the trailer under my old Apache. They worked really well, but the best part was not having to search for a hose or wait in line to use a hose after an event.
The Apache is gone, but I now have a water tank in the bed of the truck to serve the same purpose. I used a 50 gallon in bed fuel tank, added a demand pump and fittings to make it work. It doesn't have nearly the capacity of the dual tanks that were under the Apache, but it still works well.
I'll post pictures of both setups below.
ALso did it help the ride of 450, mine seems to ride better with some wt. back there.
Lynch Mob Racing
The weight of the water does make the truck ride better and between that and the extra fuel on board, it actually rides really well.
[QUOTE=Hot Duck;3023242]The tanks on that trailer we built by Myco when they built the trailer, but I imagine that any fabrication shop could make them. As mentioned by somebody in an earlier post, just be careful where you put the tanks to be sure that you don't throw off the weight distribution on the trailer.
Thanks Hot Duck very good point ,i'll take some measurements and make a few calls.Catch ya for drinks at the nawty goose
Thanks , I'm in process of making 75 " x 31 " x 8 " tall tapering to 6.5 inch 24 inches on each side for chine clearance . 90% of the 1/8 alum will be bent with bend deductions in brake and the top will be Diamond plate then welded to sides . 60 psi -4.5 GPM pump will be mounted in front under steps ( we tested this theory , i was worried about draw but it worked perfect ). Tank will be Epoxy primed then painted same color after trailer gets back from Galvanizing
Larry
Larry
Bumping this back up. Looking into doing something like this more a new to me boat going into salt.
I am looking at tanks from Tractor supply. Already have a nice washdown pump.
Just a heads up but adding a little vinegar to your rinse tank really helps cut the salt. You can use something like an adjustable garden fertilizer sprayer to add a little vinegar.
