terrible fuel mileage , out of 02 7.3 powerstroke
You should've gotten MORE mileage with the Edge unless you're running it full bore. Keep us posted I'm interested to hear what the problem was.
Is the speedo recalibrate for the larger tires? Are you figuring mpg by hand or with the computer? Level 2 isn't very much power either... I have always been told to run the larger programs and just take it easy on the go pedal for mpg. I would think even with 35 your truck should see around 12-14mpg
My mechanic says he runs his chip at full tilt and he gets the best mileage.
I run my 7.3L PSD with Bully Dog at stage 1 (above stock, 50+ HP) and leave it there; and run with the mindset that I have a massive 7000 lb. oil burning miniature aircraft carrier and don't expect great fuel mileage,
I tried the economy tow setting and didnt really much performance gain. Thought i would be safe and stay at the no.2 setting, and stay away from the "race" , thought that would be a transmission tearer upper ......
The 35 inch tires and 20 inch wheels do not help. Some tires are very aggressive and cause a lot of friction with tread patterns. Try putting it back to a stock tune and check your mileage. Are you getting excewssive smoke when you stand on it?
Wannabe
Wannabe
No I not getting excessive smoke , but I think that is because I am running transformer oil as fuel....
Knew it was coming........
I have a friend that worked for a power company , and they learned this little secret. WHen transformers are removed from service to rebuild , the rebuild company drains the oil , and puts new in. It is mineral oil and for the most part is very clean.
It burns great , and can be pretty much run almost straight.
Employees were allowed to drain it from them for a while, but Problem is, rebuild shop they were using , started demanding that the oil not be drained from them anymore.... Not quite sure , but they were claiming epa giving them problems...
Anyway the honey hole ran dry and my supply is almost gone...
Ohhhhh....
Explains it all. Less btu content....
Unless your system is set up for tranformer oil (mineral oil) you really should not run it. There are additives in the oil to stabilize it for the heat. Years ago they put in PCB's.
Wannabe
