-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   drum to disc conversion on a chevy k2500 (https://www.offshoreonly.com/forums/trucks-trailers-transportation/234936-drum-disc-conversion-chevy-k2500.html)
open87 07-18-2010 08:30 AM
looking to convert drums to disc , 2000 classic(old body) to no avail , findind a good rear end out of the newer 99-02 with discs is not working , other than 1 site that offers a conversion for extreme 4x4's ,anyone know of a place or site to find a kit to do the conversion?
Eric
DareDevil 07-18-2010 09:08 AM
Eric
trie this.....
http://www.egrbrakes.com/pdf/GM14_Da..._RDConvKit.pdf
birdog 07-18-2010 09:12 AM
Why ?
DareDevil 07-18-2010 09:16 AM
Because its 90% more breaking power !????
I will stick it on mine too !!!!!!!!!!
They also have these for single rear wheel !!!!!!
open87 07-18-2010 09:17 AM
replaced the brakes on the front end , all GM parts , just feels like the front brakes doing all the work , the drums still have a good amount of pad , wearing evenly , just seems like i don't feel them working ..
DareDevil 07-18-2010 09:18 AM
same here, and on mine ..if they get wet ( rain ) the lock up sometimes ....:party-smiley-004:
birdog 07-18-2010 09:25 AM
When did you last adjust them ?...The self adjusters are not all that great when you work a truck....A major reason for disc brakes..:drink:...But, not worth the effort/$ to change one over
bustedbrick 07-18-2010 09:34 AM
Does something feel wrong or different or is that just a general feeling you have about the truck?
Rear brakes don't do much work on cars anyways due to front engine weight bias and further weight transfer when you slow down. When you tow or haul, rears have the capability to do more work, but generally, the hydraulics are sized to be optimum for when you are not towing and safe when you are towing.
Some trucks actually have a bias (proportioning) valve on the rear axle so that when the truck is loaded, it will send more hydraulic pressure to the rear brakes.
If you do the conversion, you'll need to get the correct master cylinder for the application (and by application I mean both rear AND front caliper sizes). Lots of brake tuning is done by the OE tinkering with master cylinder piston size. If you get that wrong, the trucks handling will be whacky. Further, you'll need the right ABS tuning and those brains are tuned to apply pressure differently for drum or disc usage.
Anyway, I'm not trying to give you an instruction set but rather trying to talk you out of it :-)
You may want to try bleeding the rear circuit fully. It's rare unless you have opened it up, but possible there is an air bubble in the line that is causing less pressure to be transmitted to the rear.
open87 07-18-2010 09:59 AM
thought the ABS was located at the transmission tail BBrick? , thanks , i'm looking for as much info as possible , any info is appreciated! i understand that these Kelsey Hayes systems were not really the best..
BirdDog , just using as a daily driver now , i will see about the adjustment this week , the truck has a 454 , so i have weight on the front , maybe i should have went bigger on the fronts to begin with , but with being a 4x4 , i would have needed wheels and all that stuff , i am happy with the steel wheel/trim ring , call me simple...
handfulz28 07-18-2010 12:58 PM
Shoes need to be adjusted.
SInce the advent of ABS, all vehicles get more rear bias than they used to. GM even used a setup where the front brakes wouldn't get pressure until the valve sensed the rear shoes were making contact.
bustedbrick 07-18-2010 06:14 PM
It's sensor may be on the trans, axle, or wheel ends. Regardless, the processing by the computer is the important factor.
open87 07-18-2010 08:26 PM
Thanks , i'm going to see about changing the fluid , i looked late this evening and it is dirty , so i will attempt this week to flush out and check the adjustment on the drums ..
Eric
DareDevil 07-18-2010 08:39 PM
Eric
Not to be a smarta$$, but on my 1996 i did all that ( more then once ) and even changed the load valve or how ever u call it .
Nothing helped ..the rear drumms on the GMC/CHEVYS suck thats just fact.
Thats why i am going to do this conversion and a buddy is working for GMC he said i dont need to change anything else, the ABS will be fine !
bustedbrick 07-18-2010 10:03 PM
Both Ford and GM market good quality HD brake fluids that are a safe bet. Happy flushing!
macjazzy 07-19-2010 11:33 AM
The problem on that generation of trucks is not the rear brakes, its the front brakes. They are working too hard, but its because the pads are way too small as are the calipers.
The rear brakes were the largest diameter drum on any of the big three 3/4-1ton trucks. The front rotors are close in size to the others but GM used a small 1 piston caliper with very small brake pads.
There used to be a company that made a kit to use Ford 1ton calipers and pads on the front of Chevy/GMC trucks 88-99/00
It is a good kit because you are still using parts that are avail anywhere, not custom stuff you need to order like Willwood or something else aftermarket if you ever need parts in the middle of nowhere or on a weekend.
No sure of the name of the company right now, but you could probably find it with a google search.
