towing with a Yukon 2500
Are any of you guys towing with a yukon 2500 6.0? If so what are your thoughts?
What year/era are you talking about?
Do a search on "Suburban 2500" and "Avalanche 2500" for tips on how to make it a more stable towing platform. Also, Russ aka thp500s had a 2500 'burb with the 6.0L. He towed his 312 Formula with it. He'll have some relevant input. |
I had the 2500 Burb with 3.73 gears and the 6.0 motor. With the Formula 312 (8,100 boat, aluminum trailer) it did fine but was all I wanted to pull. If a tractor trailer blew by me it would sway the boat a little, slow to start at lights but stopped OK.
Then I bought a Formula 382 (10,500 boat, aluminum trailer).......30-50 miles tows were a white knuckle ride. Tractor trailers moved me all over the place and stopping was a well pre-planned affair. I would literally get to the ramp and have to calm down before putting the boat in the water......6 weeks later I bought a PSD dually. |
Chris: The Yukon 2500 with the 6.0 is rated to pull about 10,000 lbs and that is a good number. If you boat is more than that a 3/4 or 1 ton pickup is needed. What size boat do you have? I pull my Chris Cat fine with my 2004 Avalanche 2500 and its 8.1 liter motor- rated to pull 12k. Nobody makes an SUV that can pull over 10k anymore.
t500hps: A 382 is a heavy boat pushing at least 11k plus trailer. My guess is you were at over 13k with that set up. Formula builds stout boats. Wannabe |
towing a 28 saber. my 1/2 ton does fine, but i want more truck. the yukon is sold too... oh well there are cars, trucks, ans suv's sold, bought and traded every day - and there is probably a nicer one to be found.
Originally Posted by Chris
(Post 3179115)
Originally Posted by wannabe
(Post 3178870)
t500hps: A 382 is a heavy boat pushing at least 11k plus trailer. My guess is you were at over 13k with that set up. Formula builds stout boats. Wannabe FYI: My burb was rated at 8,600, upgrade to the 4:10 gears it went to 9,600, with the 8.1 and 4:10 gears it went up to 12,000. I figured I had the same axles, hubs, brakes, etc that the 12K version had, the only thing I was lacking was TQ and gear to get the load moving....I could at least STOP it as well as the other versions! That 382 was just waaaay too much! |
My 382 with gas, water, gen, A/C, and a steel trailer with E/H brakes weights 16100# according to the CAT scale at the local truck stop. I am pretty comfortable at 60 MPH with an PS F350 DRW. I have towed it with an F250 but do not recommend it. The main reason I like the big truck is that I lost my trailer brakes twice, and was really glad I had the one ton. Eventually you will lose your trailer brakes too. When it happens you will wish you had a bigger truck. BTW it wasn't the brakes that started the failure. Once it was a mechanic that didn't tighten a brake caliber, the other time a wheel bearing failed (same mechanic). The point is a lot can happen. An F450 wouldn't be a bad thing. The nice thing about the Fords is that they do not look like commercial trucks like the trucks from Govt Motors do. I was told by a commercial tower that the DMV picks on the commercial guys more than private haulers
Its ok i just sold mine the tans went out a few times
| All times are GMT -5. The time now is 01:29 PM. |
