1988 F-350 w/460
Was thinking RV cam and dual exhaust?? Chip? Im sure headers would be nice, but unless you buy high dollar ones, they always rot out and leak?? Plus i have the factory smog injection manifolds..
Truck seems to pull nice at low rpm, but with the TH400 3 spd, and 4.10 rear, its revving pretty good on the highway. No pull in the upper RPM. Prob due to the $hit exhaust and anemic cam
I don't have any photos, but my father recently picked up an '84 GMC one-ton dump to tow the Sutphen. The ramp we use can be pretty slippery and we needed a four wheel drive truck. This one has been gone through and is very clean.
How about the 454 TBI gasser? Mine is 100% stock and original down to the old GM pellet style catalytic converter and single exhaust. Tows decent power wise, but sure aint winning any races.
I absolutly loved towing with it, but I would get 5-7 mpg loaded, unloaded, up-hill, down-hill, left, right, and backwards. That got old.
If you do anything, do the exhaust. Best bang for the buck in my opinion.
I have an 1985 burb with 1 ton axles (4:10s) 454 with a 4l80e overdrive trans, 4" lift, 33s' and np205 transfer case.Love the body style and room but, 6mpg all the time! I'm going to put a cummins 12 valve in next and keep the 454 for something else. In retrospect I should have bought an old Dodge as much as I drive it (never).
Recently purchased this 84 Ford E-350 Van/Truck to pull my boats. Currently has a 460 with a C6 with 4:10. Very roomy and has a rear seat that folds out to make a bed. Rides extremely smooth with air ride rear suspension. Only problem is mileage, somewhere around 8 mpg at highway sppeds.
I also have the fold down back seat into a bed... Have 2 12" subs under it also that it came with.... I love the truck just dont like the gas bill
Here's a link, they are putting them on the Ford 6.4 also to try and help the MPG's some are getting 5 more. Still not great but better. I was going to put one on my Bronco but never towed much and the big tires lowerd my RPM's to about 2300 @75 mph.
http://www.gearvendors.com/f2wd3s.html
had a gear vendor o/d in my old 6.2 diesel chevy 4x4 dually . turbo 400 w/4x4 . worked great made the trucks top end 20mph faster and I towed with it on. BTW the 460 is a dog motor in stock form.
