-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   tow vehicle advice please (https://www.offshoreonly.com/forums/trucks-trailers-transportation/247523-tow-vehicle-advice-please.html)
pino56 02-13-2011 10:47 AM
i'll be towing a donzi 28zx. on the high side with boat and trailer weight plus fuel and extras i'm lookin at about 8-9k lbs. i towed locally with a f150 and it struggled a bit. i would never attempt a long haul. i wanna stick with ford. recommendations appreciated. thanks.
t500hps 02-13-2011 10:50 AM
If the F150 struggled (as I would expect) then you need more truck. The F250 would be plenty for that rig.
Expensive Date 02-13-2011 10:53 AM
+1
pullmytrigger 02-13-2011 04:44 PM
+2
ttuton 02-13-2011 06:15 PM
+3 with a diesel of course!!
Catmando 02-14-2011 01:38 AM
F250 Crew Cab Lariat Long Bed 4x4 6.7L Diesel.
pino56 02-14-2011 05:30 AM
So a big v8 gas isn't recommended, diesel is the way to go? Thanks to all i really appreciate the imput.
ttuton 02-14-2011 06:06 AM
Unfortunately Ford doesn't make a big V8 gas motor anymore. A 5.4 is hardly Big in my eyes and the V10 is the same motor with 2 more cylinder and drinks fuel like crazy.
Cousineau181 02-14-2011 06:07 AM
It really depends. If you will be doing a lot of long distance driving and towing, the diesel is handsdown the way to go. If you will be mainly driving short distances and won't rack up the miles, I would go with the gasser. The 5.4 is not enough for the F250 in my opinion.
JayFan 02-14-2011 07:14 AM
I have a 5.4 F-250 and tow a Formula 292. It's fine if you're only towing it a few miles....say to the ramp and back. However if you're towing for more than 30 miles at a time I would go with a diesel. Just a lot less strain on the engine.... IMO.
