-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   New Tahoe Towing....26ol (https://www.offshoreonly.com/forums/trucks-trailers-transportation/248317-new-tahoe-towing-26ol.html)
will22 02-25-2011 01:51 PM
Looking for everyones advice prior to purchasing a new truck. My brother is looking to uprade his tow vehicle now with future intent on buying a 26' Baja Outlaw - he is wanting to stay with a Tahoe/Yukon if possible rather than getting into the diesels and 2500hd's, he just prefers the comfort and looks of a SUV, but also at the same time he doesnt want to get into a situation where he will overwork or overload the vehicle. They are rated at 8200lbs max towing which should be well within range but he wants real world experience/advice, does anyone have this combo or have any opinions as to how this package would or wouldnt tow.
thanks in advance!
Sydwayz 02-25-2011 02:34 PM
The 26' Baja with a steel trailer (guessing--since you are midwest) full fuel, coolers, gear, lines, tools, spare parts, stereo, batteries, etc. etc. is probably going to be 8000 lbs. on the trailer ready to go down the road.
Those vehicle weight ratings are done with ONLY A DRIVER in the vehicle. That does not take into account GVWR which is what you need to consider when you have 4+ people in the truck, another cooler, several suitcases, and all the other crap we carry with us when heading to the lake/river/whatever for the weekend.
IMHO, I would not tow more than a 23 Stingray with a Tahoe/similar sized SUV. I do speak from experience. I towed a 26' Sonic which was 7250 lbs. on an aluminum trailer behind an older Tahoe that was rated to tow 7500 lbs. It was a handful.
You don't want to tow at more than 2/3s of your towing capacity. You want to have "extra truck in reserve" for those OH SHlT moments.
I'd tell him to look into the 2500 Suburban. It's going to be the right setup for him long term.
baja pete 02-25-2011 04:11 PM
I towed my Baja 272 with a Tahoe for 4 years, it worked great. I could pull it on the interstate at 70 all day long. I would still be towing with it if I had not moved up to a 34 ft boat.
mreedy 02-25-2011 05:54 PM
I've pulled my 25 nordic with a tahoe all over the place and feel 100% confident about it. Looking for a good used f250 but dont really need it for that boat.
sixmassive 02-25-2011 07:17 PM
I have know of 4 tahoes that have had transmission problems from towing. all had the "tow package." my roommate had two different tahoes. 09 and a 10. towing a 14' trailer to the track and back (110 miles each way) with 2 streetbikes in it. the 09 had one round trip and the trans went, then the 10 had 2 round trips and it went. Also his mom's 08 trans went from towing the lawn mower, and his GF from towing the bikes to the track.
that maybe just their luck, but its enough for my to stick with a 3/4 ton truck
Baja_342 02-25-2011 08:23 PM
I pulled a twin engine 29ol with a chrysler aspen no problem. 29 fountain with an expedition. Im not talking about 100 miles every weekend. I would say it depends how often you tow as to how enjoyable it'll be. Make sure your trailer brakes are in order.
JTeam 02-25-2011 08:26 PM
And this is a great point. I towed a 31 Formula with a 1500 Suburban all the time with no issues. Depending on how far you are towing and the terrain you are dealing with will determine what you ultimately need. Safety wise, I think you are fine with the Tahoe. Long term duribility is the bigger issue and trannies are always the first to go.
tylerjustinhunt 02-25-2011 08:37 PM
I think the Tahoe would do great for that. I have a 02 Tahoe that has a 170,000 trouble free miles on it that used to have towing duty for my 303. I think the 303 was a little to much boat for it but I dont think it would have any trouble with a 26ol. I have a 06 Duramax I tow with now and it just makes it pleasurable.
pachanga 02-25-2011 09:02 PM
Definately a +1+1+1! Awhile back I had a 2500 Big Block Suburban. Sydwayz won't like this but I towed a 13K trailer with it with no problems. Then I bought a 7.3 Ford Diesel 350. Wasn't a noticable difference to me...and it was a lot of city driving. The Diesel was a lot better on fuel but that bigblock would litterally walk the dog on the diesel!
PS I towed that sucker a couple times with a Tahoe and wow...no way! Not enough wheelbase on the Tahoe IMHO for max weight towing!
MILD THUNDER 02-27-2011 10:26 PM
30FT Boats with a Tahoe? I dont care if a Tahoe can pull the boat at 100mph. They have NO suspension, Small brakes, 6 or 8 ply tires, a wheelbase not much longer than a Ford Taurus. Realistically, I wouldnt tow much more than a 21FT boat with one.
Realize that a Tahoe, pulling a 30ft baja, on a steel trailer, loaded with gear, gas, and a few people, will weigh in around 16k-17k lbs total. I dont know about the newer Tahoe's, but the old 4L60E trans didnt like heavy loads. Smoked em.
I drive a semi for a living. Most recreational tow'ers don't realize how close to being on the edge of disaster they really are. Towing 10k lb trailers with a walmart hitch rated for 5k lbs, running c rated tires that are about to burst from the weight and summer heat, they think that tuggin and swaying on the back of the truck is just "normal". Never mind the fact the short wheel base Tahoe with the fact it has over 1000 lbs on the hitch, causing the teeter/tawter effect making the front steer axle so light it's gonna push right thru a turn in a emergency manuever. Brakes? Not exactly heavy duty.
The sales brochure might tell you that you can haul a 8000 lb trailer. Well, once you figure in a few people in the truck, a couple suitcases, and some other goodies, it will probably be closer to 7000 lbs trailer capacity.
My old 24FT Four Winns liberator with a single big block, on a steel trailer, weighed in at 8k lbs, with 1/4 tank of gas on the scale at the truck stop. So i can see a twin engine 29 Outlaw or 31 Formula being every bit of 10k or more. My old 40FT Formula weighed in at 16,800 on the trailer, with less than 1/4 tanks of fuel.
tylerjustinhunt 02-28-2011 12:56 AM
[IMG]http://i52.tinypic.com/qnu4j7.jpg[/IMG]
Well she didnt like it but she got the job done before I wised up and bought a diesel. I think the lower profile Nitto terra graplers really helped out with the sway, and the trailer brakes work really good but your right I was headed no where but to the scene of a accident with this rig
[IMG]http://i54.tinypic.com/24zwwwn.jpg[/IMG]
Now this Is my new rig and I feel a whole lot safer.
Quinlan 02-28-2011 07:59 AM
Hell just buy a new F150. Saw an add stating that they can tow 11500 lbs!!!
WTF!
waterboy222 02-28-2011 08:54 AM
WTF!
I bought an '11 silverado with the small v8 in it and its rated at 8800#. I can't hit 75 mph with my 7x14 cargo trailer with ONE dirtbike in it.. How the hell it could POSSIBLY pull almost 9k# is beyond me..:bsflag:
MILD THUNDER 02-28-2011 10:17 AM
When it comes to hauling heavy loads, i'll take chassis, suspension, and brakes over engine power if thats my choice. Nice to have both though. I tow with a big block gasser dually now. It doesnt have the power my chipped up diesel had, but it is what it is. So many of us have been spoiled by the high powered newer diesel pickups. Being a semi-driver, im used to taking a long time to get to 60mph when the rig's at 80,000 lbs. Its not how fast you can get to 60, its how fast you can get from 60-0 when it comes to towing! :coolcowboy:
30ctsutphen 02-28-2011 11:14 AM
Mild, I towed my 26 ft sutphen with a 97 ford expedition, air suspension package and a 4.6 litre and it towed great. never swayed once on me. If your swaying you need to stop towing imediately cause that means your distribution is way off and your gonna have a problem.
I now tow my 31 ft sutphen with a 2500 hemi dodge, It tows very well and will cover most hills better than my freinds deisels but sutphens are fairly light boats. Mine is about 5800 lbs at 31 ft . Both my boats were twin outboard boats and thats a weight savings but it also probably helps with weight distribution because all that weight is hanging off the back and boat trailers have long toungues in front of the wheels.
My car trailer loads the weight very different than my boat. much worse and needs weight dist bars. Not sure why we dont see weight dist bars on boats trailers?
Magic Medicine 02-28-2011 11:18 AM
What he said!!!! For the record Service manager GM/Ford dealership.
30ctsutphen 02-28-2011 11:18 AM
It would be very safe indeed . youd only be going 25 MPH .LOL
Magic Medicine 02-28-2011 11:25 AM
We have a customer that needed to buy a 3/4 ton truck, but only opted for a half ton. After his first trip towing his large camper, he called and said his vehicle had excessive valve train noise. When he bought the vehicle in for inpsection my tech bought this issue to my attention. rear diff got so hot all the paint on the cover burnt off. I guess the freaking genious didn't need the 3/4 ton after all!
MILD THUNDER 02-28-2011 12:26 PM
The sway i was referring to was caused by crosswinds, not weight distribution. 8k lb boat and trailer put about 900 lbs of additional weight on my rear axle according to the scale. That was a tandem axle. Triple axles do track better.
You would be surprised what your boat and trailer weigh when you put it on the scale. I have pulled everything from a bass boat to 42FT boats, enclosed car trailers, snowmobile trailers, open car trailers, and bobcats with pickups. And semi's, everything from 53ft vans, to 48 ft flatbeds loaded with steel, to 39ft dump trailers and 24ft dump trailers.
Expeditions, tahoes, escalades, and yukons werent designed to be haul vehicles. They are for getting the kids to soccer practice, and to tow the waverunners to the lake with the kids. A independent rear suspension with air shocks as the main weight carrying part of the suspension turns me off. I would never consider towing a 30FT offshore boat with one, but thats me. To each their own.
I cant justify recommending one to a fellow boater to tow a boat that is over the trucks legal limit, mechanical abilities, and or safety limitations. That one time some jerk turns in front of you, and you T-bone him, when the insurance companies get involved it can get real ugly. :party-smiley-004:
Sydwayz 02-28-2011 12:45 PM
Remember folks, surge brakes only work when the truck and trailer are tying to stop in a straight line. The instant the truck and trailer have any type of angle between them, you are going to jackknife.
Blkout69 02-28-2011 08:19 PM
Only thread so far I can actually contribute too since I do not own a boat at the moment and still learning as much as I can so hear goes post number 1 :)
Not sure how new he wants to go but friends of mine have an excursion with a diesel that is a monster of a truck. I do not know the exact towing compacity but could be a way to stick with his want/need for an SUV over a truck and still have the big diesel engine for towing and piece of mind.
30ctsutphen 02-28-2011 09:45 PM
Yep excursion is the mack daddy.
The 6 leaker can be a PITA though and needs some large bugs worked out before they are any good.
will22 03-01-2011 07:07 AM
i do appreciate everyones posts and im sure it will point out some things for him to consider before buying. Not turning this into a ford/chevy/dodge issue either but he will definitely be buying GM product so the Excursion is not an option for him - thanks tho.
