-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Trailer Tool Box necessities......? (https://www.offshoreonly.com/forums/trucks-trailers-transportation/251136-trailer-tool-box-necessities.html)
DynojetResearch 04-19-2011 11:23 AM
My truck box includes the following for trailer purposes:
  • 2.5 ton Summit aluminum "racing" floor jack - ~25# and well worth it
  • "star" lug wrench
  • 10-19mm deep sockets
  • 3/8"-7/8" deep sockets
  • combo wrench kit 5/16"-1" and 8mm-22mm
  • Ratchet and basic shallow sockets
  • 1/2" drive torque wrench with 3/8" adapter
  • 2 spare bearing buddies
  • 4 bearing buddy caps
  • grease gun
  • tub of grease
  • brake fluid
  • several feet of high-strength 3/8" chain for chaining up an axle - also 3/8" grade 8 bolt/washers/nyloc nuts
  • 6 - 12" long 2 x 6's
  • 10 spare lug nuts
That should get you out of most jams that are trailer related.
Here's Johnny 04-21-2011 11:54 AM
  • "star" lug wrench
  • grease gun
  • tub of grease
  • brake fluid
  • 10 spare lug nuts
Great list DynoJet !!!.......now I think I need a much bigger tool box for the truck.......lol......
DynojetResearch 04-21-2011 12:31 PM
Actually, you'd be suprised how compact all that stuff really is, other than the jack handle. It takes up about 1/3 of my tool box, or less. I've got one of the units that sits flush with the bed rails, so it's virtually hidden from the side of the truck.
Strip Poker 388 04-23-2011 04:43 PM
Originally Posted by Velocity Vector (Post 3374369)
A midget in the tool box in case he needs to change a flat.
How about a Trunkmonkey:drink:
[YOUTUBE]http://www.youtube.com/watch?v=8avOiTUcD4Y&feature=player_detailpage[/YOUTUBE]
bob_t 04-23-2011 08:15 PM
I only ever had to work on my trailer along the road one time, and that is when we moved from Ohio to North Carolina. I always take very good (maybe to the point of excessive) care of the trailer bearings/brakes/coupler/lights, etc. Trailer had surge disc brakes. One caliper/hub overheated going down the big mountains in Virginia on I-77. I limped into one of the rest areas at the bottom of the mountain where I was going to just swap out the entire hub. I was rather proud of myself because I had everything I needed all ready to go (spare hub with pre-packed bearings, bottle jack, hand cleaner, plenty of wipes, all of the tools necessary to change out the hub in a pre-planned "package") in the truck ... except the allen wrench that fit into the brake caliper bolt :eek:. The caliper bolts did not have the external hex heads such that you could use a socket or wrench or an allen wrench ... they were round with an interal hex. Could not pull the hub off without first removing, or rotating, the caliper. I got very lucky that one of the truckers at the rest stop happened to have an allen wrench that fit the GM caliper bolts. I now have two of those in my tool box!
Someone already mentioned about having a thin wall socket to fit the lug nuts for aluminum wheels - the wheels on my Myco require a really thin wall, deep well socket!
