How noisy is your Allison Transmission? >
Old 04-24-2011 | 06:33 PM
Tim G.'s Avatar
Performance Boat Center
This is exactly how mine is....
You'll hear it more if you have the button in Tow..
I run a PPE tuner. It makes the trans shift MUCH better.
Originally Posted by SDFever
Even with a diesel, you can hear a very noticeable whine in low gear going through a parking lot or particularly if you are off road.
Mine's an 04 with the older 5 speed. Obviously you won't hear anything if you get close to hwy speeds.
Love the tranny but hate the way it shifts. It's almost like they didn't finish the software and just left it where it works right "most" of the time.
Tim Gallagher
Performance Boat Center-FL
[email protected]
954-809-8739
Wright Performance, MTI, Cigarette, Sunsation
Tim G. is offline
Old 04-25-2011 | 06:12 AM
All I hear is turbo whistle...
THE 288 KID is offline
Old 04-25-2011 | 08:40 AM
Thanks for all the posts, guys, really appreciate it. For what it's worth, I pulled my 38' Scarab to the lake (170 miles) this weekend and it didn't skip a beat. I think the local shop was fishing for some business...or, they're not used to working on anything but mini-vans...
Griff - I've got about 30K since the last transmission flush so maybe it wouldn't hurt to do it again.
Shallow Minded is offline
Old 04-26-2011 | 02:18 PM
The early 5 speed allisons did have whine noise. More noticeable with gas engines. Nothing to worry about.
Tow-N-One is offline
Old 04-28-2011 | 04:59 AM
I've heard of more transfer case related noise than anything. Merchant Automotive in zeeland Michigan has a cure for it I believe.
Old 04-30-2011 | 01:53 PM
aquaforce's Avatar
My 06 is quiet but I recall some bulletins at the beginning of the Allison use qualifying some "normal" noise. There was some whine from a fluid pickup issue on start up but not a problem.
The pan will tell the rest of the story. If it has debris in it there is reason to look further, if there is normal gray matter and nothing else the noise is a non issue.
Good luck with the good truck.
aquaforce is offline
