-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Rim size on myco trailer (https://www.offshoreonly.com/forums/trucks-trailers-transportation/258938-rim-size-myco-trailer.html)
s022mag 07-26-2011 04:30 PM
Got a tandem axle trailer with Mickey thompson rims. Missing the fourth rim. I know there 16" rims. Bolt circle is 8-6.5 and the tire that was on it is st235/80r16. It's a classic II rim. Would that be a 8" wide rim or 10"?
offshoredrillin 07-26-2011 05:32 PM
mine are 235-85-16 and they are only 7" wide.
Sydwayz 07-27-2011 07:44 AM
16x7 wheels on most Myco trailers.
JMPH 11-06-2011 09:42 AM
I need a spare tire and rim for a 06/07 Myco, tire on it is a HT235/85R16 load E spoked allun., rim 6 bolt.
Thanks Joe
Sydwayz 11-06-2011 10:41 AM
Thanks Joe
Myco will sell you the rim direct. Then you can source a tire locally.
Also, I think www.championtrailerparts.com sells the same rims. (...the older spoked rims that Myco use to use. Myco has since switched.)
JMPH 11-14-2011 04:43 PM
trying to find one used for a spare.
