-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   6.0 Headgasket kit and stud kit (https://www.offshoreonly.com/forums/trucks-trailers-transportation/259057-6-0-headgasket-kit-stud-kit.html)
BobbyB 07-28-2011 09:53 AM
I am trying to find for a 05 6.0 headgasket and stud kit. The 18mm dowells. But everywhere i call is backordered. Anyone have a line on some? I would really appreciate it so my friend will get his truck back and i can get my truck back before he tears it up some more. :drink:
575cat 07-28-2011 12:50 PM
try rollin smoke diesel .
BobbyB 07-28-2011 01:51 PM
Actually found some today. Thanks
Strip Poker 388 07-28-2011 03:50 PM
Is the stud kit a upgrade? my 03 poped a gasket loosing water
Fixxxer22 07-28-2011 04:54 PM
The stud kit should be the same for all 6.0s the 18mm dowel ran through 06 or 07 but its just the dowel. the bolts/ studs are the same. then they go to 20mm dowels that are found in the later engines or with service oversize heads. I have hundreds of dowels 18mm 20mm and the step 18mm to 20mm when putting a new head on a older engine.
Mackattack 08-02-2011 09:34 PM
Studs are upgrade. I bought mine off of eBay ARP studs I think. Not sure if I have the name correct, but once I put them on, and did away with the eve while the engine was torn apart, I couldn't kill the 6.0.
I traded it for a 2011 6.7. No comparison, the 6.7 stock pulls better than the 6.0 chipped with propane. New truck is awesome
