-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   14" or 15" wheels (https://www.offshoreonly.com/forums/trucks-trailers-transportation/259631-14-15-wheels.html)
SunsationLarry 08-05-2011 04:09 PM
14" or 15" wheels
What are advantages/disadvantages of one or the other? I assume bigger would be better?
MrSneakAttack 08-05-2011 04:24 PM
depends on how much you gonna travel with the boat.....if it stays local you can get away with smaller...
Twin O/B Sonic 08-06-2011 05:02 AM
You can get far more weight capacity w/15's than 14's.
Standard/good 14" trailer tires will be weight capacity "C" which if I recall is approx. 1660 lbs.
Assuming tandem axle you will have a weight capacity of 6640 lbs. which sounds like a fair until you back out the weight of the trailer. which is gonna be 1500ish probably.
I couldn't figure out why I kept going through tires on the trailer under my old 24' Sonic until I pulled it across a set of scales and just about died! It was over that weight unloaded!
15' tires would have cured it.
If you do much towing (like I do), don't skimp on the trailer. I should start a thread of the crap I see down here! Some of it under brand new, high dollar rigs.
Philm 08-06-2011 02:06 PM
15" gives a much larger weight range, as stated. Go with the largest load capacity tire that you can, it is peace of mind. 14" limits you to 1760lbs a tire, 15" can give you another 500lbs or so depending on the tire.
fireboatpilot 08-06-2011 02:28 PM
And they haven't even started telling you about how much faster that smaller diameter tire is spinning at 65mph and how hot your wheel bearings are getting.
SunsationLarry 08-06-2011 04:41 PM
That was a thought that popped into my head yesterday when I saw a jetski being pulled down the highway.
tim brown 08-09-2011 10:23 AM
why use either one of those ? go 16 inch
Doug Doty 08-09-2011 12:42 PM
I'm in the market for a new trailer and I will not settle for anything else, seen too many peoples weekends or worse ruined by blown tires or burnt up bearings.
Wildman_grafix 08-09-2011 12:45 PM
That's what is on my Myco, same size as the truck pulling it.
SunsationLarry 08-09-2011 11:23 PM
I was only told about 14 or 15 from Chip at Phoenix, I will ask tomorrow if 16" is an option. Has a mag wheel option but doesnt say what size.
