-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Frontend alignment for towing? (https://www.offshoreonly.com/forums/trucks-trailers-transportation/267110-frontend-alignment-towing.html)
Hematite 12-14-2011 08:57 AM
I used to change the tie rod ends on my Ford Tempo commuter car and set the toe, myself. Not extraordinarily hard to do but without the precision of a big machine it was necessary to make some minor readjustments to get it correct.
There is a pretty narrow window on toe adjustment before too much toe chews up the outside of your tires. The factory max is really about it.
FIXX 12-14-2011 04:58 PM
fixx
this is what you do,,figure out your tougue weight with each trailer, load the back of the bed with the desired weight, add a set of rear air bags,go to the aleignment shop and add air to the bags until the aleignment shows the factory specs and remember the amount of air per trailer...makes a huge differance..
Griff 12-14-2011 06:33 PM
I highly doubt that the weight of your new 29 Islander will even move the alignment out of spec. It maybe has a 1000lbs of tongue weight and will barely make the rear drop.
