-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Escalade tire airpresure (https://www.offshoreonly.com/forums/trucks-trailers-transportation/267900-escalade-tire-airpresure.html)
Payton 12-28-2011 08:54 PM
We just got a 2011 Escalade with Nexen 285 45R22 Roadian HP. The computer in the truck says tires should be at 32 psi. Cold they are 30-31 warm about 2 psi higher. The truck rides great, but after a lane change it feels like the is a little tire squirm back to straight. I checked the Nexen website and they say 50psi max, no min. I was thinking of bumping the psi up to 40 and see how that does.
You guys have any thoughts?
Unlimited jd 12-28-2011 09:15 PM
tire pressure is directly related to load placed upon the tire, you need equal pounds per square inch inside the tire as the load placed upon it to stay up off the ground, what is the original tire size on the truck ?
tman 12-28-2011 09:16 PM
I run 40psi in a set of 20s.
Payton 12-28-2011 10:45 PM
These I thought are the originals.
Quinlan 12-29-2011 04:18 AM
WE have factor 22s on our Tahoe. I like them 5 to 8 lbs under max.
mach1magnum 12-29-2011 06:19 AM
38 on my lincoln aviator stock tires
Wally 12-29-2011 09:26 AM
It realy depends on the tire itself. Check the sidewall on the tire for what they recomend....on the dorr jam of my Tahoe it says to run the stock tires at 34psi....on the tire itself it says 60psi.
Also some tires have more sidewall flex then others. On my old dually i had "upgraded" from the stock goodyears to BFG Longtrail T/A as i was told at that time the AllTerrain T/A were NLA. :rolleyes: anyway same exact size as the stockers but these were run at 60psi as compared tot he stock ones at 50psi for towing.....when taking turns and hitting uneven surfaces it felt like the back end was "wagging the tail" due tot he tires. I hated them!!! Was a nicer ride as i think they were "softer" but the flex made me uneasy.
Right now i have a set of 20" Cooper Discoverer H/T Plus and i run them at 60psi and they rock. Only complaint i have about then is the fact they are a bit more square on the corners and the fronts are wearing the outsides from my taking hard turns. :D
MILD THUNDER 12-29-2011 09:38 AM
hey mark. I would try airing them up. I'd try going up to 40-44 cold. I always try to run my tires close to their max. Might be a little firmer ride, but gas mileage seems to be a little better. Our 2008 Grand Cherokee got over 70k miles on the stock goodyears this way, tires wore evenly. Replaced them at 70k, with a new set of the same oe goodyears, at 100k miles now and tires look great still.
Baja_342 12-29-2011 11:01 AM
I run mine close to max for all the reason MILD THUNDER said. Plus the last two cars I've had with TPMs seem to be sensitive if you barely fall under the recommended, not miunimum. I don't like warning lights going off all the time. My Lincoln won't tell me which tire is low either....PITA
A.O. Razor 12-29-2011 02:05 PM
A couple of things to notice. The max pressure on the tire sidewall has nothing to do with reccomended tire pressure. It's just what is needed when the tire is under its heaviest recomended load. Don't over inflate your tires, you will wear the center down, get a harsh ride and often get too sesitive steering. Inflate your tires early in the morning when they are cold and have not been sitting in the sun. If you have to drive somewhere, to inflate them, let them cool off before checking the air pressure. Tires are build to be inflated and measured this way, very important.
Also, don't just rely on your on board monitoring system. Get a good quelity digital air pressure gauge to use when inflating your tires.
And yes, it can simply be a question about soft sidewalls, poor directional stability and poor traction, and there is nothing you can do about that. Replace with a better tire.
Don't forget what you are driving. It's a big domestic SUV. Crisp and sharp handling is not ecxatly high on the list. If it's anything like a 2010/2011 Burb or Tahoe, it's a soft and spongy ride without much feedback. Want handling in an SUV, get a Range Rover or Cayenne ect.
Wally 12-29-2011 03:45 PM
I agree with everything you said above....i only run my tires at the max psi due to the fact i never know when i'll be towing somthing last minute and dont need to be searching for a filling station that has air available! Plus i like the firmer ride on my truck....gives me a slightly better seat of the pant feel :D
Payton 12-29-2011 07:43 PM
Thanks guys, I'll bump them up to 40 or 42 in the morning and see if that changes anything.
30 outlaw 2005 12-30-2011 02:17 PM
The stock Factory Tire is a Bridgestone Dueler H/L Allerza P285/45/R22. Sounds like the dealer changed the tires out. Did the Escalade come with the factory 22" or did you upgrade the wheels from the standard 18"? could be why you have a different tire on there.
Payton 12-30-2011 08:17 PM
The dealer said they put the Platinum rims on.
Payton 01-01-2012 08:20 AM
I air the tires up to 41-42 psi cold. On my computer they showed 39-42 on my first mile from cold. I never thought to check the psi after that. The ride was not noticeably harsher and the handling did improve. I think I'll leave them there.
Thanks guys and Happy New year.
Mark
ShadBurke 01-01-2012 12:14 PM
I run 46-47psi cold on my Escalade with 22" rims. Instead of the stock 285s, I'm running 305's.
Expensive Date 01-01-2012 02:31 PM
I always run about 38 - 40 in my wifes Escalade, now Denaili
Door say 32 I think but thats too soft and, Tires say 44 on the sidewall. It rides and handles much better with the higher pressure and I have noticed no uneven wear on either of the vehicles. They are/were also both XLs.
VortechSS 01-03-2012 08:16 AM
Hmmm... I'm gonna have to bump mine up to 44 today after seeing this.. Got some Nitto 420S 305-45-22s that just started feathering on this inside. I have been running them around 34.
Wally 01-03-2012 08:32 AM
If your tires are feathering i would go have the toe-in checked...if that comes out ok then have then inspect the bushings....somethigns causing the alignment to shift around as your driving...
