Ordered a Manning trailer... Anyone live close?
#32
I went with steel. Mostly because of looks. I have never had the boat in salt water and don't plan on doing it on a routine basis at all. IMO aluminum trailers are fugly
#33
Steve
#34
Love ours but seriously if you got any type of center caps REMOVE them. Mine held water and caused the hub/rotor to rust away. Didn't suffer any bearing damage but all the hubs/rotors needed to be replaced in what I consider to be too soon a time. We have an '08 and doesn't get much travel time on it a year.
#36
#37
Steve
#38
Most trailer manfg gets there wheeland tire combos from Tredit,I'm sure the caps are imported.I drilled a 1/16 hole at 12 and 6 and it usually drains,But it still attacks the clear on the alum wheel. Mainly around the lug nut area.The black plastic insert caps fit tight,I customized mine
My car trailer came with the stainless caps and there a 1999 and the alum wheels and caps still look new.
http://www.tredittire.com/Default.aspx
