-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   2007 F-350 Issues, Need Help (https://www.offshoreonly.com/forums/trucks-trailers-transportation/272465-2007-f-350-issues-need-help.html)
Powerboat713 03-14-2012 03:08 PM
Does anyone know if Front Dana 60 High Pinion 3.73 Gears, will work in a 2007 F-350, Diesel, 4x4?
Had a little mishap with a F-350 ( doing a burn out :479: ) and screwed the truck up...So tring to see if the above parts will work or not?
Thanks!!
articfriends 03-14-2012 06:17 PM
are you trying to put front high pinion 60 gears in a std rear, if so don't think its going to work, need more details. Never seen a ford 1 ton Diesel with ONLY a dana 60 in the rear so please clarify, Smitty
Catmando 03-14-2012 06:29 PM
We have a forum for trucks...
JPD Motorsports 03-14-2012 09:37 PM
did ya bust it up or the axle shafts and such. I was able to find replacement shafts for my rig where the dealer wanted the whole axle inner and outer shafts when i only needed the outer shortys....
Powerboat713 03-15-2012 01:42 PM
Truck is being fixed, had to get parts from FORD...
Thanks!
