Ground Clearance
Old 04-26-2012, 01:16 PM
ROADHOG's Avatar
Default Ground Clearance
When trailering, what would be a safe distance between the outdrive skeg and the ground? I now have outboards and would love to travel with them in the upright position. I have 12" between the skeg and ground.
After all the years of trailering one would think I should know the answer!!!
ROADHOG is offline
Old 04-26-2012, 02:06 PM
I dont think anybody would have an accurate numnber to give you as all boats and trailer set ups are different and how you hook it to your tow vehicle. whatever the trailer postion is thats where I would keep it.
soldier4402 is offline
Old 04-26-2012, 02:07 PM
RIPSTA Racing Team
fireboatpilot's Avatar
Does your trailer have an outdrive protector? I would be more concerned with someone getting too close to you with them in the down position and hitting them than the skegs hitting the ground. backing into something or a steep driveway entrance to a gas station or something could be a problem. Any particular reason why you dont want to trailer them in the trailering position? Seems like your taking an unnessesary risk and asking for something bad to happen.
fireboatpilot is offline
Old 04-26-2012, 02:16 PM
I trailer with mine down. I have more clearance (maybe 16-18") but 12" should be ok.
And if someone hits it drive guard or not it's gonna hurt.
POWERPLAY J is offline
Old 04-26-2012, 02:25 PM
RIPSTA Racing Team
If someone hits my drive guard the only thing thats gonna hurt is the grill of their car and they aren't coming anywhere near my drives or props. Made the drive guard myself with a 4 x 4 piece of 1/4" thick steel. Pull 2 pins and it slides right in under the drives out of the way.
Old 04-26-2012, 04:41 PM
As fireboat said, 12" seems a little low but the distance from the axle to skeg and the angles created would be the biggest concern.
Going up or down a steep drive or even backing into a tall parking block could pose a risk.
I thought it was always best to trailer in the "up" position and use a lock out or support to take forces off the transom?
What is the "love" advantage to trailering in the upright position?
ChargeIt is offline
