Like Tree4Likes
EZ-Lube or Bearing Buddy?
Old 06-10-2012, 11:03 AM
weldcrane's Avatar
My Boats: 41 apache 35 motion 17 zodiac
Ez lube has a little rubber plug in the center of the dust cover take the plug out and you will see the grease fitting
weldcrane is offline
Old 06-10-2012, 01:37 PM
offshoredrillin's Avatar
My Boats: 00 Cig Tiger,74 Cig 20'
Quote:
Originally Posted by mrfixxall View Post
ya they dont mess up the face of the wheel they push the grease through the inner grease seal and then it gets all over the brake shoes and hardware..
the only way that could happen is if you over pressurize it with air, using the same air pump as inflating sports equipment that would take lots of pumping, the grease is in static, meaning not under pressure. air just creates a positive back pressure so when it is dunked the heat wont suck water in.
offshoredrillin is offline
Old 06-10-2012, 03:49 PM
Trade Score: (2)
My Boats: 77 donzi x18 92 formula 336 sr1
Default fixx
Quote:
good to know,,ill tell by buddy that used his shop air..he blew hin inner seals and got grease every where..
FIXX is offline
Old 06-10-2012, 07:11 PM
lol, oh my, yea that's way too much, it only recommends i think 3-7 lbs. by using the ball inflator and same needle, after 3 or so pumps the rubber on the front will push out like an outtie belly button and they are good.
Old 06-10-2012, 07:13 PM
My Boats: 1979 Formula 255 Liberator...My 4th Formula
i switched to these and couldnt be happier... http://airtighthubs.com/
+1
sprink58 is offline
Old 06-10-2012, 08:03 PM
My Boats: 400 SS
Default Air tites
Grease, Grease, Greasy sheez..... With the Air tites you pack your bearings normally, Add the rear seal with the air tight sealant, put it together and your done! All you need to do is check the front rubber before you launch, If its plumped out a bit your good to go. If its flat add a pump of air from a sports pump. I keep it in my door pocket of my truck. Two seconds....NO GREASE BLOWN ALL OVER THE WHEELS OR YOU BOAT!! EZ
fossil fuel is offline
Old 06-10-2012, 08:37 PM
on the ezlubes, make sure the zerk is off to side and not in center. the cotter pin crosses the bore, restricts grease getting to rear bearing. the hubs with gear lube move "alot" easier and that would be my choice over pumping grease.
keith2500hd is offline
Old 06-10-2012, 09:21 PM
My Boats: 2008 Formula 260SS
Quote:
The 2 EZ Lube trailers that I have use locking tabs NOT cotter pins.
It's still the best system because you're able to push fresh grease through your bearings any time you want unlike any other system. Additionally, I've never had water enter an EZLube axle.
Hematite is offline
Old 06-21-2012, 11:11 PM
My Boats: Baja Force 235
Airtight is best for an existing system. I installed the airtight 4 years ago and still have the same air in them. EZ lube is nice but not swapping an axle to get it.
BadDog is offline
Old 06-22-2012, 04:09 PM
My Boats: 1987 Baja Force 265 (twin 350 mags)
Well, the more I looked at the trailer and the project, the more the parts list (and cost) continued to grow.
Screw it. Ordered a new trailer.
Kenthegreenkeeper is offline
