-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Bearing Buddy? Brand Options? (https://www.offshoreonly.com/forums/trucks-trailers-transportation/281925-bearing-buddy-brand-options.html)
Rookie17 08-01-2012 04:40 PM
Almost done with the full trailer rebuild. Like everything else in this hobby I got carried away and went over budget :D
Replaced everything, converted to 4 wheel disc with EOH, new wiring, paint, lights, wheels and tires, fenders etc and brand new Dexter axles.
Couldn't find new axles with the E-Z Lube option in the width I needed without waiting for custom made so have to run a Bearing Buddy type deal.
I've heard Bearing Buddy is now made in Puerto Rico and quality is not as good anymore. Crappy machining tolerances etc.
Anyone use one of the other brands and have good personal experience?
Tony Montana 08-03-2012 07:54 PM
http://www.airtighthubs.com/
This is what Myco uses
FIXX 08-04-2012 01:40 AM
fixx
if you done have drilled axles your better off just leaving the caps on ans put a bead of sealer around the outter lip to kep the grease dry..
Rookie17 08-04-2012 09:34 AM
Exactly what I was looking for. Thanks!!
