Best Aluminum Trailer for 38ft Cigarette?
There is a shop in Kemah, TX that has both Manning and Myco trailers right now. The boats are being repaired. I am going to look at both and see the details for myself. I found a post in 2006 that aluminum welds were breaking. I believe it was a Myco. I hope those issuses are something of the past.
I'm not so sure about that statement. My Manning aluminum is C-channel construction which I believe is typical. Now steel would be box beam, perhaps that's what you're refering to.
If you want a good built trailer Myco is the way to go. If you want a trailer built overkill Manning is the way to go.
Myco will build you anything you want. So will Manning. Myco has not jacked up their prices just for the sake of doing so. They have always been the best, and the most expensive. It's the price of aluminum and raw materials that has skyrocketed. I've seen painted ALUMINUM trailers from both of them that look fantastic. Myco will also build you a ladder bar reinforced steel or aluminum trailer as well.
The OP just missed a nice "NOS" aluminum welded Myco that sold a few months ago, built for a straight bottom TG. It sold for somewhere around 2/3s the price of new, probably less.
As soon as you talk to the other builders, and you start chewing them down on price, you components will go down in caliber and quality.
Axles, lights, wiring, 8" beam to 6" beam, same with crossmembers; not to mention braking systems, and how many axles.
In all my years of boating, I have only heard of 2 welds cracking on only 2 Myco trailers. That post the OP read here from 5+ years ago, and another friend of mine had 1 crack. You can attribute that to a sub-par core wire during the original weld/build.
I use to say McClain built a nice welded aluminum trailer after I saw a couple of them. Then I revisited those trailers a few years later and, blech! I saw plenty of broken welds then!
Myco
Manning
Top two cards in the deck; in that order. After that, you have folks that build a few welded trailers, but no one has the experience those two do.
If you need a Phillips screwdriver today, a Sunday... Where are you going to buy it? Sears or Wal*Mart? If you want to depend on it next Sunday, there is only one choice.
Myco
Manning
Mine is steel. When I had my trailer built I contacted Myco on a aluminum trailer and they gave me a quote. I then contacted Manning and he said he would build me a steel one. Too long for aluminum. Too much flex and would crack. My buddy has a 50' gooseneck aluminum Myco and has had it welded several times.
Long story short Myco will build you anything you want. Manning will build you only a trailer that will work.
If $$$$ IS a factor I would highly recommend Ownes and Son. They have been in the slide on business as long as anyone. They are in the same place with the same owners, amd you deal directly with the owners when they build for you.
I am no expert but my son and I have been hauling a 42' Harley @ 19,000 +lbs for 23 years on the same Owens Trailer. We have replaced lites, brakes, and fenders, but the frame and bunks are original. WE travel alot too. Florida to Maryland about every other year. I would guess we got nearly 50,000 miles on trailer. Have loaded/unloaded on every kind of ramp u can imagine. We are big fan of Owens products and thier staff.
BTW the 42' Harley bottom came from and older Cigarette.
