Ford 6.0 FICM
Anybody ever change a Fuel injection control module on a 6.0 diesel?
Thanks |
We change them all the time at my shop. If you go to ford & by the 1/2 ficm for around $500 you can change it yourself if your fairly handy. If you buy the whole ficm it has to be programmed by the dealer. If you have the time send it off to ficmrepair.com & they will fix it for $225.
Its no problem at all i did one in my shop today. 8mm 10mm sockets and a little patience. If you are handy with a soldering iron you can usually fix them yourself. Google ficm repair procedure and see what comes up. Also be careful not to break the retainer clips on the 3 plugs under the ficm. When you get them unclipped they will come out easy( no prying needed). Pm me if you need specifics
I soldered my own. Been going at 48v for 3 yrs now. If you buy one dont get a ford one go to bulletproof diesel.
Originally Posted by 79formula
(Post 3903866)
how much is the bulletproof ficm ?
Basic 48v is like $500. The upgraded 58v with redundant circuits is a few bucks more. Either way they dont use Ford components. Its all upgraded.
Originally Posted by tim brown
(Post 3904741)
Installing it today |
What are the benefits of changing it out ?? I have an '03 6.0
Originally Posted by Smitty
(Post 3905392)
got my half shell from USAFICM 58v took about 30 minutes to do
| All times are GMT -5. The time now is 08:31 AM. |
