-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Trailer Bearings (https://www.offshoreonly.com/forums/trucks-trailers-transportation/296218-trailer-bearings.html)
Pwraddr 05-12-2013 07:32 PM
Trailer Bearings
Hi guys,
I have a triple axle trailer with grease fittings behind the rubber plugs in the dust cap. They are Dexter hub/drum assemblies.
I was going to remove all the hub assemblies and clean and repack the bearings. People tell me all I need to do is pump in new grease until the old grease is displaced. Is this true?
If so, the only gain is being able to inspect them.
Thoughts?
POWERPLAY J 05-12-2013 07:45 PM
You can fill them till they pop too. If your going to do any real towing take them apart and pack them. Just my .02
Pwraddr 05-12-2013 08:12 PM
Thanks J. I already have the seals and new rubber plugs since mine are all dried out so I will just take it apart after I get it to Chips to get the boat off.
I'm trailering to Tawas for the races and then Boyne in July so makes sense to just do it right.
Griff 05-13-2013 01:28 AM
Originally Posted by Pwraddr (Post 3923966)
Hi guys,
Thoughts?
I have the same set up. I have had them completely apart once when I replaced all the brake plates and rear seals. Every year, I just pump fresh grease in until it pushes out all the old stuff. I do use an IR temp gun and check the hub temps at every fuel stop while trailering. Never had an issue.
Rippem 05-13-2013 06:22 AM
x2
with easy-lube spindles (I have 5 easy lube axles) just don't pump grease in too fast or you can push out or around the rear seal.
I use an IR gun also
mittens 05-13-2013 07:48 AM
I did all new bearings, races, seals, and ruber caps. i also flushed the grease out of the spindles, and use dall new GREEEN grease. I packed bearings, but then needed to fill the cavity between the two, so I did the slow motion pumping and it did come out the front, but go SLOW, you can pop the rear seal out.
Chart 05-13-2013 09:52 AM
Recently I got to replace the brakes on a farm trailer which has Dexter EZ lube spindles. The rear seal had failed, and the amount of grease that was all over the brakes and inside the drum was amazing. There was no way the brake could have worked on that wheel due to how well lubed it was.
soldier4402 05-13-2013 10:07 AM
i would think if you dont have a problem then new grease will be fine. But if its a new trailer to you, then its probably worth while to pull the hub, check the bearings, and replace the seal and pack some grease into them. If your not going into saltwater then I would think you could probably go 3-4 years in between totally tearing them apart.
Keytime 06-02-2014 03:53 PM
Had my trailer restored about five years ago and checking all of my bearings now. Which grease and bearing brand do you guys recommend?
I've been religious about keeping my bearings lubed with the bearing buddies, but I want to make sure they're in good shape.
freebirdpa 06-02-2014 06:57 PM
Just went through the process on my triple axle Eagle. New timkens, races and seals. Switched to Scheaffer 229 grease and the hubs have never been cooler! I had no problems before, but the wheels would be pretty warm to touch, since change they are cool, checked with a fluke IR and was 68-72 degrees. Thought something was wrong but all were consistent. Good luck.
Danno302 06-02-2014 07:33 PM
It's a pretty cool setup really. The grease travels back through center of the spindle and then moves through the rear bearing, into the hub cavity and out through the front bearing. If the grease is very old or contaminated I would not rely on forcing it all out with a grease gun...best to tear down, replace bearings/ races/ seals with fresh grease. Then you will keep the grease fresh with routine maintenance. Also I believe it requires a DOUBLE LIP INNER SEAL, so be sure to get the correct one!
