-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   C7 Cat Diesels (https://www.offshoreonly.com/forums/trucks-trailers-transportation/297433-c7-cat-diesels.html)
wgg 06-02-2013 06:23 PM
C7 Cat Diesels
Anyone here have any experience with 04,05,06 Cat C7 300 HP Diesel? Have a guy wants to trade me a 2005 Freightliner Toter Home with a Cat C7 300 HP Diesel with 146,000 miles Bone stock with a flawless maintence history done at Cat dealer.
I Am a Dodge Dealer so familiar with Cummins, would have no concerns if it was a Cummins but no experience with these yellow motors
Jupiter Sunsation 06-02-2013 06:47 PM
The Cat C7's are great pre-emissions which was 2006 I think
wgg 06-02-2013 07:53 PM
These are Pre Emissions(No Euria)
jpthrill 06-02-2013 08:01 PM
All good before 2007 after 2007 start buying injectors now
I have a bunch of these cat engines in buses and they work everyday
wgg 06-02-2013 08:48 PM
Can you turn up these motors up? Will mostly head east(flat and sea level) but will occasionally head west and pull 10,000 plus passes. Only pulling about 16,000 #' trailer
Cash Bar 06-02-2013 08:51 PM
If you're looking to resell the toter I'm in the market.
waycool marine 06-02-2013 09:10 PM
I have had 3 of them with no issues a 2000 -2001- in freightliners sportchassis and have 1 in my 04 650 they are reliable and run awesome all mine were 300 hp and that's enough for the big pick ups pulling about 14000, the only thing I know is there is a separate waterpump belt hidden behind the serpentine belt that has to be adjusted,
jpthrill 06-03-2013 08:33 PM
I have a sport chassis with 300 hp Benz and I pull anything no need to turn up
But there are companies out there that can reprogram ECM
wgg 06-03-2013 09:17 PM
I have heard the Benz(Detroit) motors run better.Just when we go to Powell, Havasu ,or Sturgis you have Eisenhower 11,200 feet,Vail pass 10,900, or Trail Ridge 11,400 it has a big effect. Had an American Eagle with a 350(8.3) Cummins and you could go up these passes faster than you could go down
Thanks for the info on the Cats
gofastlvr 06-06-2013 10:48 AM
They might be 300HP but it is like 800 ft/lbs of torque and I would be shocked if you needed anything else... My 08 is a beast and never any problems. I have had some electrical truck problems but nothing engine related except a coolant res float stuck and had to be replaced.
