-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   2 Wheel Drive 650 (https://www.offshoreonly.com/forums/trucks-trailers-transportation/297662-2-wheel-drive-650-a.html)
drypipetiger 06-05-2013 08:57 PM
2 Wheel Drive 650
I'd appreciate feedback as to how well or not well a 2 wheel drive f650 pulls a boat up and out of a launch?
offshorexcursion 06-05-2013 09:31 PM
If the ramp is not steep, is dry, no algae, etc. you will be fine. But for some reason those big trucks with DRW do NOT have good traction. Might be the stiff suspension, open diff, etc.
I personally use a 2wd Cummins Manual trans to easily pull my boat our of a steep ramp with zero problems. Not even a slight tire slip. I even have to back my trucks rear tires 1/4 of the way under water. There is no slime on the ramp though.
A F650 with or without a limited slip rear diff will benefit if you "simulate tire traction" to both wheels by lightly holding the brakes. Lots of weight over the rear axle will help with traction also, plus help it ride better. Lowering the rear tire pressure will help if you are In a bad situation, but obviously will need to be inflated to tow the boat home.
I watched a newer lifted F650 struggle to pull a 43 Sunsation out of a half cement half gravel ramp. The gravel road to the ramp left some gravel on top of the cement incline and the 2wd F650 threw rocks all over the beautiful boat. Plus the ramp is so short the trailers tires fell off the end of the ramp and the frame was dragging a little. He made it out after a few not so fun to watch attempts.
drypipetiger 06-05-2013 09:34 PM
Thank you for responding. This was my fear. Not too many 4x4 650's avail.
302Sport 06-05-2013 10:32 PM
The ride difference is night and day with the 2wd over the 4wd
seafordguy 06-06-2013 06:08 AM
Seem to be a lot more Kodiaks/topkicks with 4x4. I think in 20 years when the kids are off my payroll I might lean to a Kodak for that reason.
waycool marine 06-06-2013 07:51 AM
I have had a couple sportchassis and now have a2wd 650 and have had zero problems, the truck is heavy 12,000 , if you let the air out of the air ride it puts a lot of weight on the rear end.I pull a café racer package about 13,000,14,000 no comparison to ride or stopping.
PRIMECUT 06-06-2013 08:45 AM
There out there just not as cheap as you can get a 2 wheel unit for
gofastlvr 06-06-2013 10:44 AM
My 650 has pulled my 42' Fountain and the MTI with no problem on any ramp any where. If you have trouble you can let the air out of the back bags and mine has a diff lock button on the dash but I have never had to use it... Now if you can't drive and punch it you will spin but just get it rolling and you shouldn't have any problems.
drypipetiger 06-06-2013 11:50 AM
Anyone ever buy a himarc conversion from Aquasun in Florida?
Sydwayz 06-06-2013 12:06 PM
This silver/blue one is owned by ROGMAN here on OSO:
2007 Ford F650 Custom Paint - Aquasun Motorsports
http://www.aquasunmotorsports.com/im...jpg?1245250610
