mercruiser overheat
hi guys i need help , i have 5.7L mercruiser 260HP engine and it overheats. I have cleaned the outdrive and made sure there was nothing blocking the water intake. I have also replaced the thermostat making sure it was not stuck. Now it over heats and i dont know what to do . Is there anyway i can flush the cooling system. The impeller is also good . How do you flush the cooling system also the engine is a 1991 with alpha outdrive. All help will be appreciated thank you ,
Welcome to OSO.
First this thread is not in the right place. You should have it placed in a section that it more pertains to. Have you checked the oil cooler? the water path runs from the drive to the oil cooler then to the engine. If impeller pieces, trash etc get clogged in the oil cooler the engine will not get much flow resulting in the very symptom you have described. |
Did you replace the impeller in the outdrive?
Originally Posted by Port Monster
(Post 3958462)
(Post 3958462)
Originally Posted by aquaforce
(Post 3958325)
Welcome to OSO.
(Post 3958325)
Welcome to OSO.
Originally Posted by soldier4402
(Post 3958792)
yup guarenteed thats the problem
A two year old impeller can go on you. Just because it is working at idle doesn't meant you do not have a cracked or busted blade. As normal maintenance after 2 years I would change it just to rule it out.
(Post 3959241)
(Post 3959512)
right it might have enough left to spit some water in there. Check it and change it, and try again. Other than that, you would have a blockage somewhere.
Originally Posted by boatingdennis17
(Post 3959871)
yes but as funny as it is i took the boat out today and it was fine in the 170-180 degree mark . also the water spits out like a power washer so i am pretty sure its not the impeller .
Originally Posted by sprink58
(Post 3959890)
With this knowledge why do you think it's over heating?
Borrow a laser temp reader and confirm the temp on the manifolds themselves. Also look for steam coming out of any of the tail pipes. If temp is confirmed and there is no steam them move on bit keep your eye on the temp gauge.
but wouldnt 170-180 be a little hot. Mine runs 140-150. but maybe on with a different thermostat.
If your Alpha system is all stock you sure do have an oil cooler for eng and PS together. The drive impeller pushes the water up in the path I mentioned and it doesn't matter if the cooling system has the impeller in the engine bay or in the drive, failed impellers will pass through the system and the cooler is always where they stop because they can not pass through the small cooler holes. The cooler is located on the bottom of the block, usually on the port side. Pull the hose off the incoming side, usually the hose toward the rear of the cooler, and look right there for debris or pieces of impeller.
| All times are GMT -5. The time now is 05:19 PM. |
