7.3 oil pans
What are you guys doing with the rusting leaking oil pans to fix it short of pulling motor to fix? Mine is not leaking yet but is badly rusting and flaking off and I have painted it earlier.
Almost hate to admit it, but JB welded a temporary patch on mine .... 2 and a half years ago still good!
2 choices pull the motor or cut the crossmember if you're good. And only if you're a talented welder/fabricator. Problem with pulling the motor is you end up doing manifolds, oil cooler, up pipes etc
Damian Diesel pan saver and never worry about it again.
Originally Posted by lil red
(Post 4053602)
Metal gas tank repair kit works great be quick it sets up real fast .
There is a local guy in Buffalo that will do 7.3 oil pans for $750. He lifts the motor. When mine goes I will cut and weld my crossmember.
Iit also has been done by pulling the turbo for more lift clearance .
Look up the por-15 trick. I did it on mine and it lasted
I have used the Damiens diesel pan saver before with GREAT luck. very easy to install and has had no issues for 3 years now. def would go that route if I were you.
