-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Looking for basic Trailer tires. Any recommendations? (https://www.offshoreonly.com/forums/trucks-trailers-transportation/307712-looking-basic-trailer-tires-any-recommendations.html)
Knot 4 Me 01-23-2014 01:42 PM
Originally Posted by jvthundercat (Post 4061927)
In a comparison, I would not take FREE Marathons if I could pay full retail for Maxxis. It is not worth the trouble to me with the "life" experiences that I have had.
Yes, they are that good. No heat build up, no scoffing. I have gone through a new set in less than 1000 miles just from turning with a triple before.
I almost went with Maxxis but I wanted new wheels and Treddit did not offer them as an option. I've ran Marathons on all 4 of my trailers for thousands of miles over a 16 year period and have had zero failures. Therefore, I was comfortable sticking with them. However, just as with Carlisle some folks have had horrible luck with Goodyear. I've heard nothing but good on Maxxis.
Sydwayz 01-23-2014 02:14 PM
Originally Posted by Knot 4 Me (Post 4062016)
Brian, my new ST225/75/15 Goodyear Marathons are D load rated.
Thank you.
I can only fit the 205s on my little boat's trailer.
Currently running 205/75/14s at 26.11" tall.
Going to jump up to 205/75/15s at 27.11" tall.
The 225/75/15 at 28.29" tall; and nearly and inch wider is not going to work.
The trailer was built in 1976 or so. Everything was smaller back then, myself included. :D
underpsi68 01-23-2014 09:22 PM
I installed a set of Maxxis 225/75/15 E load and couldn't be happier.
cyrus77 01-24-2014 12:30 PM
For some reason my trailer is 1981 and has "Turbine" style "Mags" that are 14x7/ I do not know if you can (scratch thay SHOULD) put a 215/75/14 on a 14x7 rim...Anyone. If I don't use these I will buy a premounted tire/wheel.
Knot 4 Me 01-24-2014 12:44 PM
You think the wheel is too wide?
sbslinde 01-24-2014 01:17 PM
If is is a single axle trailer you can use an automotive tire with no issues. I would look to go 15" in a lower profile if it will meet your weight needs.
