What if you
Old 10-21-2014, 11:52 PM
Received 4,326 Likes on 1,241 Posts
Default What if you
Get a flat on your trailer, you plug it but now how do you air it back up. You air compressor isn`t going to reach 20' from the truck!
I think Im losing it
ICDEDPPL is offline
Old 10-22-2014, 12:05 AM
You've got way too much time on your hands!
Rbesola is offline
Well, I guessing you took it off to plug it... roll it upto the pump.......
phragle is offline
Old 10-22-2014, 12:36 AM
Just a little side note on plugging tires and I don;t think this holds true for bias trailer tires.
I have been big time tire plugger for 20 years and especially for about 10 of them as this town went crazy with construction for a while and every other day there was a box of screws sitting in the middle of the road that fell off someones roof.
So back to the point. I was told by a very knowledgeable person that has been in the tire manufacturing biz along time that todays tires do not do well with plugs. They laminate the plys differently nowadays and a plug will allow air to flow between them and it will cause the tire to delaminate between the plys.
So if you have a tire that is worth a chit when it gets a hole in it you should really have it patched from the inside instead of a plug.
tommymonza is offline
Old 10-22-2014, 01:18 AM
Received 1,821 Likes on 907 Posts
I have never had a trailer tire get a flat without trashing it anyway.
Griff is offline
Old 10-22-2014, 05:28 AM
I use my jumper/starter that I can keep in my truck.... I've used it a bunch of times as it has a cigarette lighter plug. Getcha one!
I like the way you think though.
SkiDoc is offline
Old 10-22-2014, 05:50 AM
Quinlan's Avatar
Exactly!!
BUT I did put a air adapter on the back of the 650- Now I just need 50' of hose
Quinlan is offline
Old 10-22-2014, 11:16 AM
What if you: stay focused on getting your boat back together, "maybe"? it'd be ready by springtime.
payuppsucker is offline
Old 10-22-2014, 12:51 PM
So should I patch this one, or will a plug suffice?
Ryan
Ballistic Beak is offline
Old 10-22-2014, 12:57 PM
SB
Received 3,116 Likes on 1,403 Posts
Ryan
Black RTV.
Red is actually better but won't match the tire well.
SB is offline
