Originally Posted by FIXX
(Post 4250394)
if you have access to a lift then pulling the bed would be easier if the bolts come loose..i have the straps on the tank,,you have to run a tap over the threads first to clean the threaded part to get the nut off the strap or the strap breaks..
Originally Posted by buck35
(Post 4250403)
Good to know, i have two straps also.
I disagree. Airtex is worse than schit.
I wish they never existed. They cost me lots of money and time and bad customer mojo. Should have been wiped off the parts map years and years ago, Go to hell Airtex. |
Originally Posted by sb
(Post 4251019)
i disagree. Airtex is worse than schit.
I wish they never existed. They cost me lots of money and time and bad customer mojo. Should have been wiped off the parts map years and years ago, go to hell airtex. my brother inlaw was hurting for money so like a bumb azz i ordered one for like 38 bucks over the ep385 ac delco one..well after i put the fuel in the tank i turned the ing on and herd a ziiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiip and that was it..the phucking pump locked up.. |
(Post 4250392)
SB,,when you go the the dealer it comes in a ac delco box..delfi is the module part of gm but yes napa had the delfi brand..
I brought up Delphi here cause I almost exclusively use Delphi fuelp pumps....especially for GM. Airtex is brutal. |
I probably sold 50 or more Airtex pumps in a short time before the first failed...then the second...than the third....than the 4th...on and on and fUking on and got damn f*king on.
Warranty ? Huh ? What mutha fker warranty ? No labor...no nuthin...but we'll send you another one. Then onto "maybe you are installing them wrong" and then "maybe you are sabotoging them." Those quotes from 1tech help + a supposed engineer and 2nd from the distributor...in case someone from that company ends up seeing this thread. They have nothing to lose when all the blame is on the installer and/or reseller. Hell's too nice of a place for poser manufacturers. Way better if I took the $$$ out of my pocket and thrown it in the street. I'd have no labor involved and would have happy people liking me. Thus why I get bitter with other poser manufacturers too...Procomp obviously is modeled the same way. |
(Post 4250397)
Well my pump came in so I checked out the tank again, pump is under extra cab so ill be dropping it, or just lowering it I hope .lol
thanks again, ken |
Recently had a Delphi go bad in 6 weeks. Good part was it was in a Ford Escape (don't have to pull tank). Bad part, it was my wifes Escape.
Yes I was warned, I bit the bullet and ordered through the local dealer.550, chaching .
Okay, so2 bolts 3 screws, 3 hoseclamps later the tank is down but the pump will not come out , I see on the new one a couple clips whichseem to need squeezed, but nuttn, wtf?
lil red if you did this on a 29 midmount in 90 mins.your hired ! |
| All times are GMT -5. The time now is 12:28 AM. |
