bleeding trailer brakes
what's the best way to get this done, about 42', brakes on two axles, serge type system. use a vacuum pump to bleed them ??
You can also take the guard off the e-brake lever and have a buddy work it manually like pumping a brake pedal.
Vacuum pump is fastest.
Say yes to the vacuum pump! I have a triple axle and the E-brake was to much a pain in the but
Can you get that pump at Vato Zone, NAPA ect.
Originally Posted by 33outlawsst
(Post 4300282)
http://www.mityvac.com/ Fancy version. http://www.autozone.com/test-scan-an...mString=search |
http://m.summitracing.com/parts/mvp-0101
I bought this bleeder 2 years ago to do my trailer. I would never do one again without it. Money well spent. |
Which of the Summit universal one do you need for trailer brakes, they list different applications, is it the one listed above bu underpsi68
Originally Posted by underpsi68
(Post 4300369)
For the cheap bass turds in the house....
Considering I use it about on e a year, it fit the bill. http://m.harborfreight.com/brake-ble...not%20provided |
I prefer the pneumatic system from HF - the reservoir bottle alone is almost worth it even if you buy the manual vac pump system too.
Easy to do with only one man and have a larger reservoir of fluid for visual reference so there is no risk of sucking air. http://www.harborfreight.com/brake-f...der-92924.html Boat off the trailer makes life even easier. |
(Post 4300369)
I bought this bleeder 2 years ago to do my trailer. I would never do one again without it. Money well spent. It is freakin awesome. Best way to bleed brakes, even abs systems. |
| All times are GMT -5. The time now is 10:07 AM. |
