-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Friends 2014 F250 air filter warning. (https://www.offshoreonly.com/forums/trucks-trailers-transportation/326221-friends-2014-f250-air-filter-warning.html)
Wobble 05-14-2015 11:12 AM
A good friend had his oil and air filter changed a couple of weeks ago. Yesterday the FRAM air filter came apart and jammed up his turbo, had to be towed to dealer. They said it's not the first one.
So I will add Fram air filters to do not install list. Fram oil filters are already on it.
FL335i 06-18-2015 08:39 PM
^That's bad. First I've heard of that one. I NEVER use fram oil filter, never had issues with their air filters... but I can see that happening.
wannabe 06-20-2015 04:25 PM
I use only AC or Wix filters for a reason.....
SB 06-20-2015 05:25 PM
Yikes.
They should just change the name to Jam.
indysupra 06-20-2015 05:43 PM
Service manager at a ford dealer here. Have seen several that are not seated and torn at the foam. I wouldnt use anything Fram.!!!
Sydwayz 06-20-2015 05:55 PM
Another NO FRAM user here.
BUP 06-21-2015 09:42 AM
Me too found out in 1991 all about Fram oil filters - Mercruiser V-6 had one installed and notice oil pressure readings fluctuating -
Removed it, then cut open and the cardboard end caps had collapsed. Very poor quality and use cardboard end caps. Installed a Wix, oil pressure readings were fine after that.
I do not buy their stuff anyways but thanks for air filter update.
Sydwayz 06-21-2015 10:49 AM
FWIW, Fram Oil filters wrecked and/or killed several people on motorcycles back in the 90s.
They had a bad run of oil filters that separated with heat and dumped all the oil under the bike, causing the motorcycles to wreck.
I've never, ever touched one since.
Wobble 06-22-2015 10:33 AM
We think the filter got wet due to about ten consecutive days of driving in the rain, stock airbox setup, he is trying to pursue it with Fram.
VoodooRob 06-22-2015 10:50 AM
There was a time in the mid to late 90s that when getting your bike tech inspected for roadracing if there was a Fram on the bike it was a 'no-go". Frams had been falling apart while running or just blowing right off the threads. Ran stock filters on all our race bikes, never an issue.
