Good LED high performance headlight replacement
Can someone give me a recommendation for higher performance/led/halo headlight replacement for 2011 F250 and 2010 Suburban. I know there are lots out there. Looking for function more than looks. Thanks
My sense is it may be another year or 2 until we get there. Diode Dynamics is who to try
IMHO, https://www.gorecon.com/ has the best direct factory swap out light systems available. Do not go with eBay specials on this purchase.
Also, I'd replace any/all fog lights with a product from http://www.rigidindustries.com/ I have a Rigid LED knock-off from eBay on the gill guard of my Chevy. So far, I'm just as impressed with the product I got from Rigid a few years ago for my Ford. My Chevy's eBay light bar: $145 (few months ago) My Ford's Rigid light bar: $800 (several years ago) |
Originally Posted by Sydwayz
(Post 4366034)
Originally Posted by Tractionless
(Post 4366035)
What's the lumens of your Ebay special? Been looking for one for my 2006 F250 bumper opening where OE foglights typically lay; however, didn't know where to start. Probably going to get something for the rear bumper as well for loading unloading at night.
http://www.ebay.com/itm/321824775354...%3AMEBIDX%3AIT I just searched for the most Wattage I could find the Length I was looking for, and I wanted the adjustable center mounting brackets; not end ears. I have it relay powered & triggered to my bright lights. It's like aircraft landing lights when I have that thing turned on. I have diodes that keep my low beams and fogs on too when my brights are turned on, and now the LED bar too. On my Ford, IIRC, I have a 20" Rigid double row bar in the front grill opening. (My truck is a 2000.) I also have Rigid 2x2 lights under the rear bumper. I have my rear view camera AND my rear facing LEDs hooked up to a switch under the dash so I can turn them on/off at will; not only when transmission is in reverse. I can leave that switch turned on to load at night, AND I can check my coupler/hitch setup at 75mph going down the interstate after a bad bump. |
(Post 4366040)
This is the exact light I bought for my CheBroLet:
For the Suburban go to the retrofit source TRS- and get a HID setup. Much brighter... 35 w will knock your socks off.
Wannabe |
A friend of mine installed Spyder led & halo combo kit to replace his entire factory lense and parking light on his F250. Fit, finish and look was good. I was looking into the same for my Dodge and will also look at the above TRS.
Go HID or dont even bother.
I have some http://www.racesportinc.com/ in my Jeep and love them.
| All times are GMT -5. The time now is 08:53 PM. |
