-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Anybody ever seen or done a Avalanche dually? (https://www.offshoreonly.com/forums/trucks-trailers-transportation/331938-anybody-ever-seen-done-avalanche-dually.html)
phughes69 10-26-2015 10:48 AM
i've always wondered why no one has converted a 2500 Avalanche to a dually. 4 doors, big block short wheel base for easy turning. I remember Chevy made a 4 door short bed dually in 2000 or so that was marketed towards people who pull fifth wheels and campers. I have sen the adapters to convert the 3/4 axles to dually hubs but never seen dually fenders for a Avalanche.
wannabe 10-26-2015 11:50 AM
The Avalanche is on the Suburban Frame, not the pickup. Putting dually fenders on one woud be tough and resale tougher.
Go ahead and give it a shot!!!!
Sydwayz 10-26-2015 12:27 PM
1 Attachment(s)
I owned one, but never considered it. The problem with the Avalanches is their wheel openings are small. That restricts your wheel/tire size choices unless you lift.
Upgrading an Avalanche to a dually is never going to give you the stability you are looking for. I LOVED my Avalanche, but the frame just isn't that of the HD line of trucks. I could see my frame flexing aft of the rear axles when I was towing within factory specs. That's when it was time for me to sell it; and I bought a dually.
Now I have an F350 Superduty & a 2500HD Chevrolet.
My 2003 2500HD Chevrolet long bed/extended cab,
4x4, 4.10 gears, 8.1L gas & Allison 5 speed automatic; pretty much stock on 33" tall tires.
My 2002 2500 Avlanche was:
4x4, 4.10 gears, 8.1L gas & M32 4 speed automatic; lots of bolt-ons including 32" tall/wider tires (see mods below), exhaust, tuner, FIPK, and a few others.
My 2500HD truck tows 12K lbs. MUCH better than my Avalanche EVER did.
I know we can't all afford to have multiple vehicles, but I would suggest dumping your 2500 AV and getting an older HD/Superduty truck for towing only, and picking up a 1500 Avalanche for a daily driver.
Found this pic online, but looks to be a photoshop. To my knowledge, all of the 2500 Avalanches had cladding.
[ATTACH=CONFIG]546982[/ATTACH]
Sydwayz 10-26-2015 12:35 PM
The best bang for your buck to improve towing stability on the 2500 Avalanche (or 2500 Suburban):
2" rear wheel spacers
Ditch the factory 6.5" wide pizza cutter wheels and go to 8" or 9" wide wheels & wider tires.
I was running 17x8 Helo wheels and 265 series E-rated tires on my best setup.
I also had rear airbags on my AV, but in hindsight they may have been actually contributing to my frame sag issue.
https://scontent-iad3-1.xx.fbcdn.net...61&oe=56B45806
https://scontent-iad3-1.xx.fbcdn.net...36&oe=56D1F1F9
575cat 10-26-2015 01:40 PM
Arrow craft out of mich would be the place to ck out .
phughes69 10-26-2015 07:13 PM
No I don't own one. I have a 1996 C3500 extended cab dually. I was just wondering if anyone had converted one. I remember 20 years ago that the Suburban dually's were a cool conversion and wondered why no one did something similar to the Avalanche or even the newer Suburbans
vindicator101 10-26-2015 09:58 PM
Older model Sub but gives the general idea. Like said already the 2500 Av has the cladding which would be problematic. I have actually thought about buying a 2500 Av and swapping out my non clad Av body of my 1500 so I would end up with a 2500 with no cladding.
http://i1082.photobucket.com/albums/...psqjeqwt9r.jpg
