Who makes the best leveling kit for 2001 Chevt 3500 crew cab 4x4?
My tow truck looks low in the front , anybody raise there's up a few inches?
it should be a torsion setup where you can raise it, as long as its not a huge amount. just check the alignment after it.
Thank bud, hope all is well!
UCA systems are the best if just leveling is what you are after. These are very high quality I have one of their lifts: http://www.cognitomotorsports.com/ch...eling-systems/
If you're just looking for an inch or so then turn up your torsion bar pre-load a little. I think mine are about 5 turns in on the adjustment bolts compared to stock. Be warned that this changes your toe a little so it is wise to get an alignment afterwards.
| All times are GMT -5. The time now is 05:09 PM. |
