Mine has the dreaded highway vibration. 72 mph, and there's a vibration in the seat, wheel and center console. Several road force balances, tires, shocks, and left rear axle, it's still there. Mine has the flip down seat/center console which I think makes the vibration feel even worse since it only has the connection point at the hinge.
Did (4) trips to the dealer, with minimal change if any, and GM agreed to a new truck. I'm taking a chance on a '16, because I couldn't buy a comparable competitor brand for anywhere near what I paid for the 15. Other than the vibration, it's a gorgeous truck, with a nicely finished interior. Mine is an SLT, crew cab, 4wd with the Max Tow. The new one is also be a max tow, so with the 6.2, 8 speed and 3.42 rear it should scream. |
You will enjoy the 6.2 motor compared to the 5.3! I know I did.
6.2 is a great motor. Just turned 100K on my 09 Tahoe LTZ. Not one issue so far. I think the u joints may be going tho. I do drive the pizz out of it! MPG 14 and requires 91 as stated.
Originally Posted by ziemer
(Post 4398034)
Originally Posted by Gimme Fuel
(Post 4398205)
Mine is smooth as can be. No vibrations except the stereo haha. Now every Ford F150/F250 I have ever driven shakes worse than an Epileptic with ADHD and you can't get it to stop no matter what you do for tires/balancing.
(Post 4398205)
The truck I traded was a '12 FX4 Crew Cab. Had the ecoboost and never a problem. Only complaint was the crappy front rotors. Had just shy of 100k when I traded it.
| All times are GMT -5. The time now is 01:23 AM. |
