-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Which airbags? (https://www.offshoreonly.com/forums/trucks-trailers-transportation/335241-airbags.html)
fordf350 03-07-2016 06:46 PM
Which airbags?
There are a whole lot of airbag systems out there and I just don't know enough about them to make a intelligent decision. I will be installing them on a 08 F350. For the most part it is my daily driver. But it is the truck I use to tow the boat. After installing a leveling kit on the frontend I am worried that the trailer weight will drop the a$$end to much. What has been working or not working for you? Thanks Mark
offshorexcursion 03-07-2016 07:20 PM
Kelderman offers 2 different options for the rear
Firestone R4TECH
http://www.sdtrucksprings.com/index....ducts_id=16756
Firestone Ride Rite (put over 600,000 trouble free miles on them)
Air lift
Lots of others
johnmiffco 03-07-2016 07:41 PM
firestone
and when not towing leave a few lbs in them so they don't pinch
have them on 2 tow vehicles for yrs and no problems
jtbooten 03-08-2016 02:33 AM
Bought some airlift bags 2 years ago from sd trucks. Seemed at the time to be the best deal on the Internet. Certain times you buy, airlift offers rebates. As stated above keep a few lbs in them at all times.
VoodooRob 03-08-2016 06:30 AM
Have used Firestone with the in cab gauge and fill option, worked flawlessly.
ICDEDPPL 03-08-2016 08:43 AM
Preferred air bag?
http://img.ifcdn.com/images/7ccbfde6...9f44f118_1.jpg
Sydwayz 03-08-2016 10:13 AM
Firestone and Air Lift are made in the same factory. (Firestone's)
I have run both with no issues whatsoever. I've had them on 5 different trucks.
If you are installing an air system, make sure you visit www.hornblasters.com
It's the best $800 I've spent on a tow vehicle.
fordf350 03-08-2016 01:13 PM
Funny you said that I was thinking I could tie the airbags into my horn compressor.
575cat 03-08-2016 01:57 PM
Originally Posted by ICDEDPPL (Post 4413031)
Those will cause you more problem,s & maint , but would love to get your hands on a pair of them .
Sydwayz 03-08-2016 02:22 PM
This is what you need, off one of the unused ports on your tank:
http://www.truckspring.com/products/...5lxxoCilLw_wcB
You have to run air lines into the cab of your truck, but that's really not a big deal.
There are also wireless kits as well, they are not really 'add-on' kits, plus you have to run power and ground; and they are expensive.
http://www.4wheelparts.com/parts/fir...ntrollers.aspx
