older 2500/3500 4x4 gm Caution.
2 Attachment(s)
Wife was driving my truck last night and started to back into a driveway, when the left front went through a hole the pitman arm ball joint snapped off. I get all our vehicles checked over once a year at a local front end shop and was about due for this truck.
Four years ago they installed a moog pitman arm due to play in the original gm unit. (He has since stopped installing aftermarket parts unless you bring them to him due to other issues) After searching I found that moog has a problem with their pitman arms for our applications, so beware[ATTACH=CONFIG]556737[/ATTACH][ATTACH=CONFIG]556738[/ATTACH] 2006 GMC 2500hd crew 4x4 238k miles no lift kit, front keys turned up an inch with shock extension (still nose down) |
Grrreat. I just put a Moog on my truck not too long ago. I've always considered them as good as factory, but that is scary.
Originally Posted by ChaseO
(Post 4454461)
| All times are GMT -5. The time now is 02:23 AM. |
