-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   brakerite ehb problems (https://www.offshoreonly.com/forums/trucks-trailers-transportation/338876-brakerite-ehb-problems.html)
mikesystem01 07-01-2016 11:16 PM
hi guys and gals i got a brakerite electric over hyd and the board in the pump under the cover is shot anyone know if they sell them by it self ? i called around and not much luck i got the 5 wire one and and thinking of buying the control module for the brakerite 2 and rewiring it
the motor work pump works fine anyone done this dont look to hard just a few wires and thats it thanks
ALL_IN! 07-05-2016 01:15 PM
I was having problems when I first installed mine - turned out to be a truck problem. But I just called up Brakerite (multiple times) and spoke with a tech guy. There were decent help.
mikesystem01 07-13-2016 09:11 PM
found mine had a bad solider on board i fixed it now
Scagburner 07-14-2016 06:32 AM
While were on the subject of Brakerite problems... Mine is starting to drip a little brake fluid out around where the wires enter up thru the bottom. I haven't opened it up yet to find the source but has anyone had trouble with these units leaking?
I think I'll pull the cover off it this weekend.
