KOdiak 225 90* Line Fitting Size?
Does anyone know the thread pitch and size (both sides) of the 90* brake line fitting that screws into the caliper?
I couldn't get the 90* out of the old unit (boogered it up) and a used caliper I bought didn't have one installed. Thanks for any help you can lend! Keith |
I'm away right now to check but I believe the fitting is 1/8" npt and 3/16" inverted flare. The fitting also has a restrictor hole in it. I have an extra one that I removed from my old caliper I can send you when I get home if you can't find one.
Originally Posted by underpsi68
(Post 4575107)
Keith |
Verify, but this one looks to be it:
Replacement Kodiak Brass Adapter Port for Disc Brake Calipers |
Originally Posted by SB
(Post 4575122)
Replacement Kodiak Brass Adapter Port for Disc Brake Calipers Keith |
Originally Posted by Tractionless
(Post 4575296)
Thanks and yes Etrailer.com verified that although not pictured the fitting is included.
Keith Anyway, if trying to go local, 1/8" NPT to 3/16" FIF 90* fitting. 3/16" FIF = 3/16" female inverted flare Inverted flare is very common. |
(Post 4575308)
I'm not sure what you are saying. That link is for the fitting/adapter itself...the one you are asking for. Or do you mean another one ?
| All times are GMT -5. The time now is 04:30 AM. |
