-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Trailer Strobe Light Setup (https://www.offshoreonly.com/forums/trucks-trailers-transportation/352084-trailer-strobe-light-setup.html)
PremierPOWER 01-31-2018 10:46 AM
Wanting to add strobe lights to a trailer on the sides and rear. I would like to be able to control them from the truck cab somehow. Does anyone have a setup like this? Have tried googling quite a bit and have not really found anything.
Sydwayz 01-31-2018 10:54 AM
Do you have auxiliary switches on the truck? (Ford and Ram offer these from the factory on their higher end models. Easy to add something as well.)
Simplest thing would be to add a wireless controller that uses a keyfob to turn on the trailer strobes on demand, powered by the 12V+ to the trailer.
Second simplest thing would be to add a second wired connection to the trailer, perhaps a 4-way flat connector wired up to your auxiliary switches.
There are 7 wires in your 7-way connector, and they are all used. So you can't add another function inherently.
PremierPOWER 01-31-2018 12:10 PM
Sorry, I should have clarified. I am not wanting to use the 7 way, I am wanting either something wireless or something I can install a switch in the dash and have a second harness plug in the bumper/ on the trailer for these lights.
Sydwayz 01-31-2018 12:20 PM
You are not going to find a "kit" for this.
But have your trailer manufacturer install the lights that you want, and wire them to a separate circuit with a pigtail left for you at the front of the trailer.
Then take the truck and trailer to any competent stereo/electronics/aftermarket shop, and the can present you with a few options. It's really not a big deal. You could even have it be controlled totally wirelessly via an optional output on an aftermarket alarm. You could get real creative, and even have it trigger said alarm if the trailer is disconnected from the truck for some reason. Not hard stuff, but not COTS product either.
kevinb230 01-31-2018 09:38 PM
What is the purpose of these lights? Color? location?
Quinlan 02-01-2018 05:29 AM
2 Attachment(s)
Do you Really need a reason:gfight:
PremierPOWER 02-05-2018 02:35 PM
Oversize/ wide load. I bought 4 of these on Amazon that I plan to install. 2 on the sides/ 2 on the rear corners
Cash Bar 02-05-2018 06:49 PM
I will be speaking with a strobe specialist company here in S Fla. They do almost every emergency vehicle on the area and service all of them as well. A am starting a refurb on he Skater trailer and wanting plenty of bling factor.
RollWithIt 02-10-2018 09:02 AM
Greg, you and Yvonne are the bling factor for Mad Props.....
Cash Bar 02-10-2018 11:00 AM
Well, me more than her, but thanks. LOL :lolhit:
